OK, so I'm Sanding My Bottom... - Page 9 - SailNet Community
 12Likes
post #81 of 98 Old 05-02-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Re: OK, so I'm Sanding My Bottom...
OK so I tried a second coat of clear epoxy today...
Clear over clear is still clear... I could not "see" what I was covering/missing so I stopped after a few sq/ft..
Spent the rest of the afternoon "scuff sanding" the dry clear coat hoping the sanding scratchs will guide me as I apply second layer...not totally convinced...
What i would like is to "tint" the next layer so I can "see" where/what I'm covering...
What can I add as a "tint".. I read on google a small amount of artist oil paint woiuld work, mixed with epoxy resin...I have some...any other suggestions...?
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is online now
post #82 of 98 Old 05-02-2012
Senior Moment Member
SloopJonB's Avatar
Got to a fiberglass supplier and buy some tint - it only costs a few bucks.
SloopJonB is offline
post #83 of 98 Old 05-02-2012 Thread Starter
Superior Sailor
Squidd's Avatar
WEST SYSTEM - Projects - Adding pigments to epoxy
Dry Anilines and Tempura powder also had high adhesion ratings both of which are available to me .... Better adhesion than the rit dye or the enamel paint suggestions I've read...
"Captin Ron"
post #84 of 98 Old 05-02-2012
travlin-easy's Avatar
Don't use anything oil based--it will retard the drying process.
Good Luck,
Gary
travlin-easy is offline
post #85 of 98 Old 05-03-2012 Thread Starter
Superior Sailor
Squidd's Avatar
I don't know why I didn't think of it eariler...Carbon Black...about as inert and you can get...
Couple drops toned a batch black...just enough to see the new coating...
Two coats epoxy abour 12 to 16 mil barrier on top of fill and fair...starting to look presentable from what I started with...
Three days of "cureing" while I go off and watch the daughter graduate Nurseing School.. and then back to put two coats of hard Biocide paint on...calling it good for now...( I want to go sailing...)
"Captin Ron"
post #86 of 98 Old 05-11-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Finally got first coat on...
One more coat and then a new waterline stripe...
"Captin Ron"
post #87 of 98 Old 05-11-2012
Lookin' good Squid!
Gary
post #88 of 98 Old 05-12-2012
Closet Powerboater
MedSailor's Avatar
Looking great! And adding the Crestor(tm) to the mix will keep the cholesterol from sticking to the bottom too!
Nice job!
MedSailor
MedSailor is offline
post #89 of 98 Old 05-12-2012
bljones's Avatar
Pharmaceuticals, painters supplies, epoxy and a boat- You gotta love this guy's workspace.
It's 5 o'clock somewhere:
bljones is offline
post #90 of 98 Old 05-13-2012
Bill SV Rangatira
Bill-Rangatira's Avatar
Send a message via Skype™ to Bill-Rangatira
Originally Posted by bljones View Post
Squidd,
Ditto what jfdub said.
If you want to be in the water this season, forget you saw what you saw, mix up some slightly thickened epoxy, slather it on the exposed mat, roll it out, mix up some fairing compound, slather it on, sand and shape it, cover it with some barrier coat, bottom paint and go. In the fall, soda blast it and spend the winter cleaning it up.
Agreed only thing I might add is to put some mat and roving layers or at least chopped strand in any big holes
You might want to check into a gelcoat plane? like a electric hand jointer for shaving off gelcoat not sure who makes them but I'm sure someone more knowledgeable might have the intel
Bill-Rangatira is offline
bottom paint removal: sanding vs. stripping Krist Gear & Maintenance 5 10-17-2011 09:22 PM
Light sanding vs sanding vs heavy sanding jarcher Gear & Maintenance 1 05-17-2009 01:45 PM
Do it yourself sanding TheKnapps General Discussion (sailing related) 4 07-12-2008 11:19 PM
wet sanding johnnennis Gear & Maintenance 12 11-05-2006 08:05 PM
