Rod Rigging - SailNet Community
post #1 of 4 Old 04-18-2012 Thread Starter
davidpm's Avatar
Rod Rigging
The boat I'm working on a Beneteau 32s5 has discontinuous rod rigging.
How does one inspect this kind of rigging?
What are the issues?
davidpm is offline
post #2 of 4 Old 04-18-2012
tommays's Avatar
Re: Rod Rigging
On the 35' the mast comes down every season which is not realistic for most owners
The issues are things like the fittings that go on before they head the rod in the machine seizing in the cups and the heads do work harden
The other issue is the threaded sections of the turnbuckles have the shortest rated life by navteq of anything in the system
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 4 Old 04-18-2012
Re: Rod Rigging
You check for forzen fittings and sockets, make sure they are lubricated, and preferably do a dye check or scrutinize them for stress cracks.
NavTec organizes things by what they call a "Class A (B) (C)" inspection, based on the number of years or miles the rigging has been in use. Every so often they call for taking down the whole rig (Class C) to go over all the bits in detail. At shorter intervals, it is just inspected in place. Give 'em a call, sometimes they answer the phone & email.
hellosailor is offline
post #4 of 4 Old 04-18-2012
jimrafford's Avatar
Re: Rod Rigging
Navtech is in Guilford in the old Flexible tubing building. They will refer you to a rigger.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
Rigging gerryB37 Gear & Maintenance 8 11-16-2010 09:04 PM
Junk/Sampan rigging vs. Cat rigging ClaireFAISE General Discussion (sailing related) 10 09-21-2010 09:59 PM
rigging MDQ Gear & Maintenance 7 09-30-2007 08:16 PM
J/40 rigging i670684 Gear & Maintenance 2 05-08-2006 05:57 PM
rigging dankel Gear & Maintenance 2 06-20-2005 02:18 PM
