Backing plates for life line stunchions - SailNet Community
 2Likes
  • 2 Post By PaulinVictoria
post #1 of 6 Old 04-18-2012 Thread Starter
sevseasail's Avatar
We got the boat a few days ago (a 1980 Catalina 22) all the life lines came in a box with what appeared to be everything.
I'm trying to get the boat ready to launch this weekend.
As I'm preparing to install the life lines I realize the backing plates are not there.
I can order from Catalina direct but they wont be here on time.
Can I use a section of 1/2 solid oak as a temporary plate till the stainless steel plates arrive?? Once I got them I can replace them one by one with the life lines in place, right??
Do you guys see any reason why I should not do this??
Thank you all for your responses !!!!
sevseasail is offline
post #2 of 6 Old 04-18-2012
Cherp
Re: Backing plates for life line stunchions
I have seen all sorts of things used as backing plates for stanchions - washers, pieces of solid timber cut for the task, pieces of Plywood, solid stainless plate etc. If The stanchion bases are put on well (see Mainesail's advice here) and don't leak, your solid pieces of timber with stainless washers should be a permanent fix.
Cherp is offline
post #3 of 6 Old 04-18-2012
Remember you're a womble
PaulinVictoria's Avatar
Just put it back in the water without the lifelines. Plenty of boats don't have them (and frankly they don't really do much for the most part anyway). When your backing plates arrive, fit them. Cover the holes in the meantime. No point doing the job over and over
mitiempo and SloopJonB like this.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #4 of 6 Old 04-19-2012 Thread Starter
sevseasail's Avatar
Thank you guys for your responses.
Here's what I did. Later I will order the correct plates and shorter screws
post #5 of 6 Old 04-19-2012
*probably* not an issue but I would have rounded the corner to prevent stress concentration...
sailordave is offline
post #6 of 6 Old 04-19-2012
tap
Use some fender washers and you can probably call it good. Better backing than a lot of stanchions have.
tap is offline
G10 backing plates sailordave Gear & Maintenance 17 01-02-2012 08:19 PM
Backing plates micheck General Discussion (sailing related) 7 11-14-2010 02:27 AM
Backing Plates painkiller Gear & Maintenance 29 02-19-2009 03:17 PM
Backing plates SVCetacea Gear & Maintenance 53 12-01-2007 09:01 PM
Backing Plates TXS-ALAMO Gear & Maintenance 6 10-31-2007 09:03 PM
