04-20-2012
Sailor
Outboard Help needed
I believe I have the same engine. I know on mine that there is a knob that turns to tighten and makes it that the motor won't swivel in that bracket. I don't see this knob on yours but I see where it seems to belong. If you look on the shaft, right behind the clamp where it attaches to the boat, there is a "bump out" where I think you should find threads for a bolt with a knob for the head. Simply tightening that know puts pressure on the shaft, keeping the motor from turning. I must say that since I don't utilize it often, I might be fuzzy on the details but I know that there is a simple mechanism for doing what you seek to do. Look at the manual?
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
