Bristol Finish in humidity - SailNet Community
post #1 of 8 Old 04-20-2012 Thread Starter
Looks like a washout weekend. That's not so bad for getting some of the list knocked off.
I have Bristol Finish on my cockpit table and it needs a top coat. The cockpit is fully enclosed right now, so rain would be kept off. I'm wondering if the high humidity might be a problem.
Jeanneau 54DS
Minnewaska is offline
post #2 of 8 Old 04-20-2012
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Re: Bristol Finish in humidity
Might take longer to fully dry(?)
Daniel
1981 Nor'sea 27,
Who is staring at the sea is already sailing a little.
-Paul Carvel
Rhapsody-NS27 is online now
post #3 of 8 Old 04-20-2012
No first hand experience, but I doubt it. Unlike water based paint, Bristol doesn't dry, it cures and gives of some solvent. I'd be interested to hear about your general experience. I find horizontal surfaces to work very well. Controlling runs on vertical surfaces seems to be a challenge.
Islander 30 MKII "Sojourn"
shogan50 is offline
post #4 of 8 Old 04-20-2012 Thread Starter
Only applying to horizontal table and cockpit coaming.
Jeanneau 54DS
post #5 of 8 Old 04-20-2012
I've used Bristol Finish for years with pretty good success, but this Spring I twice had to re-do the top coat because of dew issues. Instead of a high gloss, I got a splotchy matt finish.
I'd be a little reluctant to try it in excessive humidity, although since I'm at Cape Canaveral, FL, I'm not sure I really know what "excessive humidity" is. That's pretty much the norm.
richard_reinhart is offline
post #6 of 8 Old 04-20-2012
bigdogandy's Avatar
Dock
I've used the Bristol finish before in the summer in Florida when the humidity was 90% or better and had good results each time.....but like Shogan said the cure time is a bit longer when it's humid out.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #7 of 8 Old 04-20-2012 Thread Starter
Good stuff. Thanks. Turns out we've been diverted for the weekend and will have to take it up another time.
Jeanneau 54DS
post #8 of 8 Old 04-21-2012
Worth checking with Bristol. Anything that uses water or other solvents, tends to have problems when the temp and humidity get high enough. Sometimes it is just a slow cure, sometimes a haze, sometimes it doesn't get as smooth. For the price of a phone call, always worth checking.
hellosailor is offline
Anybody elsed have trouble with Bristol Finish? SoulVoyage Gear & Maintenance 20 01-20-2016 09:46 AM
cabin humidity mikieg General Discussion (sailing related) 2 01-02-2012 10:13 PM
Humidity PBzeer Living Aboard 2 05-27-2006 10:23 PM
Bristol Finish Pilgram Gear & Maintenance 4 03-30-2004 04:49 AM
Humidity Control shall Gear & Maintenance 0 03-17-2003 04:48 PM
