rebedding my hatch lexan (if that's what it is) - SailNet Community
 3Likes
post #1 of 24 Old 04-20-2012 Thread Starter
Last fall kids assaulted our harbor and kicked their way into my boat. They stomped the forward hatch until the plastic came out of the frame. Nothing is broken, but the duct tape holding in the plastic now is neither waterproof, secure or aesthetically pleasing. Should I use a clear acrylic caulk?
glmark is offline
post #2 of 24 Old 04-20-2012
Re: rebedding my hatch lexan (if that's what it is)
I replaced my hatch glass (actually some kind of polycarbonate) last fall. I used the material recommended by the manufacturer, and bought from them (Atkins and Hoyle), which I believe was GE SCS2000 (I'll check when I get home and update this post if I was wrong). This is some kind of silicone, I think, but it's really tough and flexible and made a great seal to the aluminum hatch frames. I highly recommend it.
Brian_A likes this.
1979 Gulfstar 37 Laissez Faire
rmeador is offline
post #3 of 24 Old 04-20-2012
Maybe something like this?
Noah's Marine Supplies Online Store - Sikaflex 295uv
Somekindofaviking is offline
post #4 of 24 Old 04-20-2012
If it was lexan ( a plast of bullet proof tecnology, that could deflect a bullet, but would cloud from salt water) The kids probably could not break it.
how is it mounted. I have found Screws tend to do funny things to lexon when torcked down.
I have always perferd 3 M 5200.
If it is fastened bed it apply. & clean up any over flow, with WD40 (Water Displacment formula 40) it's the solvent.
It's moisture activated (Works under water) & once bedded and cures flexable.
JC Boyce
jcboyce is offline
post #5 of 24 Old 04-20-2012
mitiempo's Avatar
The better sealants recommended by hatch experts like Select Plastics Which Sealants To Use
are Sika Flex 295 UV which requires a primer, GE SG-4000, and probably the most popular Dow 795.
Brian
mitiempo is offline
post #6 of 24 Old 04-20-2012
Senior Moment Member
SloopJonB's Avatar
I used this and was very happy with it. Its primarily used for bonding curtain wall glazing on high rise buildings so it's probably O/K for a couple of square feet of hatch glazing.
SloopJonB is offline
post #7 of 24 Old 04-21-2012
I quit using Silka Flex more years ago then I can remember. I would guess I used 75 to 95 tubes of 5200 for instaling moldings, ports, trim, standing rigging, through hulls, antina's, Flybridges ECT & about 45 tubes of life ****, & 3 cans of like **** primber, for teak decking.
I will need to reff & recaulk 2 teak seems, & may have to recaulk a rubrail because the customer hit a pilling.
My policy is if the proccess works well, don;t change it but Thank You for your enformation
jcboyce is offline
post #8 of 24 Old 04-21-2012
mitiempo's Avatar
Ah, so you're the one that's used 5200 on all the items that the owners can't remove without damage.
Brian
mitiempo is offline
post #9 of 24 Old 04-21-2012
Actually I havn't had to break glass down to dust, &n cut the bedding off with a wood chissel since before the formula changed back in the 80s.
But If your primary concern is how easily a part you are installing will come off, rather then that the vessel will return home safly. we are working to different ends. Mine is saftey.
But back in the 70s the boatworks called together 6 boatworkers including my self to get oppenions on how best to do something. the only thing I remember was 6 professionls came up with 7 oppenions.
jcboyce is offline
post #10 of 24 Old 04-21-2012
mitiempo's Avatar
I guess one professional couldn't make up his mind.
Safety has nothing to do with it. The sealant or bedding keeps the water out. The fasteners, commonly machine screws, hold the fitting in place. Except for acrylic ports which should never be attached with 5200.
I am grateful that everything above the waterline including the hull/deck join on my 1977 CS was bedded with butyl. Easily removable and very few leaks since new.
Brian
mitiempo is offline
Gluing/Welding Cracked Lexan/Acrylic Hatch? FishFinder Gear & Maintenance 2 05-31-2010 07:53 PM
rebedding. old issue, particular Q:grinding/lexan QuickMick Gear & Maintenance 7 02-06-2010 09:29 PM
Lexan thickness for deck hatch Alden68 Gear & Maintenance 38 03-13-2008 06:05 PM
Lexan Replacement Hatch for C30 latitude9.5 Gear & Maintenance 1 07-04-2006 12:14 PM
Rebedding leaking lexan ports jhoover3468 General Discussion (sailing related) 12 12-01-2003 09:17 PM
