Dark spots on the rudder - what am I looking at? - SailNet Community
post #1 of 7 Old 04-22-2012 Thread Starter
billsull's Avatar
I have these dark spots on my rudder, but not on the hull for some reason. They don't feel wet to the touch. Am I looking at a concentrated case of blisters?
Bill Sullivan
Allied Seawind 30
Bristol 24
Old Saybrook, CT
billsull is offline
post #2 of 7 Old 04-22-2012
One of None
deniseO30's Avatar
Re: Dark spots on the rudder - what am I looking at?
The rudder has water intrusion, very common. very easy to fix, near impossible to prevent.
First thing to do is drill a hole in the bottom! Prepare thyself for lots of sanding, filling, and barrier coating. "been there done that"
My last project!
deniseO30 is offline
post #3 of 7 Old 04-22-2012
Denise,
Unless you took it apart, and verified that the post and straps are still in good shape then it really isn't repaired. I don't believe there actually is a way to keep water out of a rudder, too much going on there for it to remain completely sealed. The low oxygen environment inside a rudder blade is really bad for crevice corrosion on stainless. I took mine apart because there was serious corrosion of the post between the blade and the hull. Turns out the post and straps inside the rudder were all aluminum, and bright and shiny like the day it was built 28 years ago! The serious corrosion was caused by electrolytic action from copper bottom paint reacting with the aluminum. I was able to find out what the alloy was and welded it up.
The good news is that splitting a rudder and putting it back together again is a relatively simple process.
Gary H. Lucas
GaryHLucas is offline
post #4 of 7 Old 04-22-2012
One of None
deniseO30's Avatar
Yup, I know Gary, so far mine is still rather solid and no brown ooze yet. I was going to take it home this winter but since we had no winter to speak of.
My last project!
post #5 of 7 Old 04-22-2012 Thread Starter
billsull's Avatar
A waterlogged rudder.... *sigh* One more item on the spring to do list. Thanks for the tips, Denise.
billsull is offline
post #6 of 7 Old 04-22-2012
One of None
deniseO30's Avatar
I wonder if there is a dry rudder anywhere that's not new. Don't despair Bill
My last project!
post #7 of 7 Old 04-22-2012
Sabreman's Avatar
Ours. Just dry, unblemished paint, thank goodness.
Sabre 38 "Victoria"
Sabreman is offline
First anchoring in the dark. flyingwelshman General Discussion (sailing related) 19 02-07-2012 02:23 PM
light vs dark xort Gear & Maintenance 5 09-19-2008 09:12 PM
It is dark here max-on General Discussion (sailing related) 4 07-23-2008 04:56 PM
Anyone seen these spots before?? cas8100 Gear & Maintenance 4 05-07-2008 03:30 PM
Dark water drynoc Gear & Maintenance 3 03-04-2007 10:10 PM
