Name that deck fitting - SailNet Community
post #1 of 8 Old 04-22-2012 Thread Starter
What is this thing?
I leads into the anchor locker.
extremo is offline
post #2 of 8 Old 04-22-2012
Closet Powerboater
MedSailor's Avatar
Re: Name that deck fitting
Hawsepipe.
The slot allows you to close the lid without disconnecting the anchor chain.
MedSailor
MedSailor is offline
post #3 of 8 Old 04-22-2012
Since your rode doesn't go through the hawse I'm assuming someone added a windlass, making that fitting redundant. It is a source of water into your chainlocker so if that's the case I'd remove it and cap it.
Faster is offline
post #4 of 8 Old 04-22-2012 Thread Starter
Thanks!
I assumed that the windlass and this hawspipe were both original on the boat, but I guess when things are 30+ years old, +/- five years is hard to tell [if in fact the windlass was added later]. I think I will keep it to run a second chain out if I need to.
When we got the boat there was a sewn sunbrella cover that was lost in a nasty beating leg a few years ago. It was held on with velcro. Making a new one would reduce the amount of water that could get in.
extremo is offline
post #5 of 8 Old 04-22-2012
dnf777's Avatar
Chain cleat. Allows anchor chains to be stored in the locker and at least partially protects from water ingress.
dnf777 is offline
post #6 of 8 Old 04-22-2012
Closet Powerboater
MedSailor's Avatar
Originally Posted by extremo View Post
Thanks!
A sumbrella cover is much more ship-like than what I'm about to propose, but these other, field-expedient alternatives have been tried and tested to keep water out on a passage:
1: Stuff a nerf ball into the hole (apparently this works very well)
2: Line the hawespipe with cling-wrap then spray a bunch of expanding foam into it. The foam will create a custom made plug but won't bond to the hawse because of the cling-film. You can also cast a pope or light chain lanyard in the middle of the foam plug.
3: Mummify the hawse with duct tape and cling film before a passage.
4: Stuff a tennis ball into the hawse.
Another idea I had was to make a sumbrella cover, in the shape of a cone, and sew it ON TO the chain rode. It would receive more wear and tear by going overboard but as a part of the rode it would never be misplaced and would always be right at the correct link to seat it over the hawse.
MedSailor
post #7 of 8 Old 04-22-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by MedSailor View Post
3: Mummify the hawse with duct tape and cling film before a passage. MedSailor
The Red Green solution.
SloopJonB is online now
post #8 of 8 Old 04-22-2012
Mike K
Good nice fitting I will give U 20 bucks for it !!!!
WHISPER55 is offline
Waste deck fitting cvsheppard Pacific Seacraft 2 07-28-2010 06:39 PM
Broken deck fitting runner Gear & Maintenance 3 09-01-2008 10:26 AM
Frozen Deck Fitting SUNDANCE2653 Catalina 6 10-24-2007 08:56 AM
Tiller to deck collar fitting.... Culinary411 Cal 1 06-23-2007 01:17 PM
Fitting a hatch in a cambered deck Crip Gear & Maintenance 1 08-28-2003 01:46 AM
