This mystery has me beat. - SailNet Community
 5Likes
post #1 of 15 Old 04-22-2012 Thread Starter
jppp's Avatar
Boat is on the hard.
Removed cover to do work.
Noticed diesel on the ground directly under cockpit drain.
Noticed that diesel had/was dripping from cockpit drain.
Diesel fill is in floor of cockpit.
Dipped tank with that stuff that turns red if water is present. None found.
I thought that the drains had become clogged causing water to flood cockpit, seep into tank and push fuel out.
Noticed vent tube had diesel residue on it.
Fuel is definitely coming from vent.
I had shut off the fuel valve on the bottom of tank months ago.
I'm 90% sure I topped off tank to the brim and added stabilizer and biocide before putting boat to bed.
What could cause this?
Heat?
We had some unseasonably hot weather 90+ degrees.
1985 C&C 35 MK 3
jppp is offline
post #2 of 15 Old 04-22-2012
creedence623's Avatar
Re: This mystery has me beat.
I'd figure that if you really did fill the tank to the brim, the fuel's expansion from the heat caused a bit of an overflow.
S/V FREEDOM
2002 Beneteau 393
I'm a sailor, I sail!
creedence623 is offline
post #3 of 15 Old 04-22-2012 Thread Starter
jppp's Avatar
I can't for the life of me think of any other cause.
jp
1985 C&C 35 MK 3
jppp is offline
post #4 of 15 Old 04-22-2012
One of None
deniseO30's Avatar
Pray to the tank gods that the tank doesn't have pin holes in the bottom? The gods were not so kind to my tank about 3 yrs ago.
My last project!
deniseO30 is offline
post #5 of 15 Old 04-22-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
I've always been advised to not fill diesel tanks to the brim. i'm thinking Creedence is on the money.
Hey Denise .... your pin holes ? What tank material ?
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #6 of 15 Old 04-22-2012 Thread Starter
jppp's Avatar
I was thinking full would reduce chance for condensation. There is never a free lunch.
1985 C&C 35 MK 3
jppp is offline
post #7 of 15 Old 04-22-2012
It does, just not to the very brim of the tank. It's typically a good practice to leave a little space for expansion (which isn't super-uncommon).
S/V FREEDOM
2002 Beneteau 393
post #8 of 15 Old 04-22-2012
ldog68's Avatar
We have had this issue on the boats I used to work on. We learned to always leave expansion room. Fuel is pretty cool temperature wise when you get it from the dock storage tanks. Add heat from the sun, heat from a running engine and the fuel would always expand. It takes some trial and error to find your topping off mark,.....
Catalina 27 under refit.
Catalina 22 and O'day 14 Javelin to play with while working on the 27!
ldog68 is offline
post #9 of 15 Old 04-22-2012
Learning the HARD way...
eherlihy's Avatar
Wile you said that you filled the tank before putting her to bed, you didn't mention if the tank was observed full when you dipped the tank... If the fuel level is still at the top, then probably expansion (either that or the birds in your area are poopin' diesel ). If the fuel level is lower than it was at bedtime, then you have probably discovered a leak.
eherlihy is offline
post #10 of 15 Old 04-22-2012
One of None
deniseO30's Avatar
TDW, the original tank on my boat was aluminum. there was a slight presence of fuel in the bilge under the prop shaft, later on (about a year after having the boat) it was showing up in the bilge over the keel. the plywood supports were soaked. 1982- 2009 not a bad life time for a tank imho. Have a moeller polyeth tank in there now. just wish it had baffles.
My last project!
Beat The Heat !! Canuckster General Discussion (sailing related) 3 07-16-2010 10:36 AM
Indentifying Mystery Hardware (Mystery to me anyway) :) krozet Gear & Maintenance 7 04-19-2010 05:26 PM
Beat the taxes WinterHawk34 General Discussion (sailing related) 10 01-20-2010 06:41 PM
Didnt beat the front in. kmdudley7 General Discussion (sailing related) 16 04-07-2009 05:05 PM
My Outboard Finally Beat Me! berkshire1 Gear & Maintenance 2 09-15-2008 11:44 PM
