Depthsounder Troubleshooting Help - SailNet Community
post #1 of 3 Old 04-22-2012 Thread Starter
I may be wasting my time, but...
I have a Horizon DS45 Digital Depth Sounder. I neglected to turn off the DC power and let it run for three days. Now it will turn on, give a reading and then the screen goes blank, no numbers, no dashes, nothing. The first time I tried it, it only displayed data for a few seconds. Today it displayed data for nearly half a minute. Turn it off and back on after a few minutes and I get momentary data. The owners manual's trouble shooting chart is worthless, it does have a schematic but the print is too small for me to read.
What now? Are these repairable? How do I isolate between Transponder and Readout Head failures?
Help?
John
ccriders is offline
post #2 of 3 Old 04-22-2012
Old as Dirt!
svHyLyte's Avatar
Re: Depthsounder Troubleshooting Help
Help?
John
John--
Look at your owners manual for a hard reset. Typically that involves holding down two of the buttons on the face of the unit while the power supply is off and then having a helper turn on the power to the unit. This will clear out the memory but typically restores the factory pre-sets and the function of the unit. You can then re-set your keel off-set to match your boat.
Having the unit operate for several days shouldn't have any adverse effect. (When we're in the Keys ours runs constantly for days at a time.) You may just need a hard reset to resync you control head to the transducer.
FWIW...
svHyLyte is offline
post #3 of 3 Old 04-22-2012
You might simply have a bad power supply connection. When it first turns on it probably is just starting up the processor and display, so a poor connection gives enough voltage for that. Then when the sounder starts pulsing the higher current drain pulls the voltage down and it shuts off. Check the voltage right at the units power supply connections.
Gary H. Lucas
GaryHLucas is offline
Palmer 60 troubleshooting rlmccb Islander 2 02-20-2012 07:51 PM
need a transducer for a uniden qt206 depthsounder rappitysnap Gear & Maintenance 3 02-17-2012 05:35 AM
SIGNETMARINE SL172 Depthsounder Mauiwowie General Discussion (sailing related) 2 05-17-2011 10:44 PM
Vhf Troubleshooting FWFIV Gear & Maintenance 20 03-18-2007 10:58 PM
Navico 200 Depthsounder Martincoyote MacGregor 0 11-07-2006 12:51 PM
