Rusting Anchor Chain...What to do? - SailNet Community
post #1 of 3 Old 04-22-2012 Thread Starter
Rust has replaced the galvanized coating of my anchor chain.
Any coating that I can apply to help the situation?
I was considering some rust converter like Naval Jelly or soaking the chain in oil. Half of the 300 ft is affected so swapping the chain end for end would kick the problem down the road for now.
Thanks,
Neal
ncapener is offline
post #2 of 3 Old 04-22-2012
Courtney the Dancer
jrd22's Avatar
Re: Rusting Anchor Chain...What to do?
The only long term solution to the problem is to have it re-galvanized (make sure they have a centrifuge for chain, not all galvanizers do). You should also check the diameter of the rusted links to see how much steel you have lost. A little rust is no big deal but if you've lost a significant amount of the original diameter it might be time for a new chain. Factoid; one inch of steel will make seven inches of rust +/-.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 3 Old 04-22-2012
TQA
Bombay Explorer 44
TQA's Avatar
You will almost certainly find that it is not economic to have the chain regalvenised. Sand blasting and the regalvenising charge will equal or exceed the price of new chain.
TQA is offline
G5 5/16 HT Anchor Chain interlude44 General Discussion (sailing related) 4 12-21-2009 08:10 AM
Stainless chain plate rusting L124C Gear & Maintenance 11 03-30-2009 03:36 AM
Anchor chain geoffr98 Gear & Maintenance 4 07-29-2007 04:09 PM
anchor chain SteveCox Gear & Maintenance 11 07-22-2006 07:39 PM
Anchor Chain Jade Sky Gear & Maintenance 0 11-18-2002 08:20 AM
