Old 12-10-2003
kmeeks's Avatar
kmeeks is on a distinguished road
Send a message via Yahoo to kmeeks Send a message via Skype™ to kmeeks
ideas for mounting solar panels on a 32 ft. sloop
Hi,
I''m hoping some of you may know of some web sites where I can find interesting ideas on mounting solar panels on a space-limited boat.
Old 12-12-2003
h37skipper is on a distinguished road
Some dockmates have beefed up either their dodger frame or bimini frame and mounted the solar panels on top. Another added a frame outside the pushpit that can be folded flat or adjusted to the correct angle for that hours sun. My own plan is to add another 2" stainless post opposite the radar tower. Then I will add a stainless tube between them and mount a large(120W) panel there. Finally there are several arch companies:
http://www.topsinquality.com/
http://www.gate.net/~radrarch/
Old 12-13-2003
WHOOSH is on a distinguished road
K, especially because you''ve got a smaller boat, loading it up with add''l windage and weight higher up/further aft isn''t a great idea. If you use google and some of the vendor website search engines, you''ll find multiple vendors who offer cockpit lifeline mounting kits for solar panels, and these can be folded down (when they will lie parallel to and outboard of the lifelines just forward of the stern pulpit) or propped up for use, whether underway or on the hook.
A related change you might consider is installing a stainless tube between your aftermost stanchion and your stern pulpit. When entering/exiting the cockpit, this might be helpful as an add''l handhold, it will be a stronger support for a solar panel, and also serves as a better anchor for weathercloths should you choose to install them at some later date.
Jack
Old 12-14-2003
jamesonatom is on a distinguished road
Here''s a link to a page with a photo of a custom solar panel mount that has survived several ocean passages:
http://www.atomvoyages.com/projects/improvementprojects2.htm
I have not found a better place for minimum shading than above the pushpit, though for some the windage and aesthetics of this are not acceptable. Depends on your priorities.
James B
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Solar Panels sneuman Gear & Maintenance 3 09-24-2004 03:06 PM
ideas for mounting wind generator on a 32 ft. sloop kmeeks Gear & Maintenance 1 12-13-2003 02:34 AM
Siemens 65 Watt solar panels pjfsail Cruising & Liveaboard Forum 10 07-21-2003 09:30 AM
Solar Panels for Catalina 27 pdecker General Discussion (sailing related) 0 03-20-2002 03:28 AM
