Shoot Thru Hull Transducer - Page 3 - SailNet Community
post #21 of 26 Old 04-26-2012
Re: Shoot Thru Hull Transducer
Hello all.....Same problem here with Norcross Hawkeye 'thru hull' transducer. It works when dipped over the side but fails to provide signal to the display when set in the hull of the Catalina 22 swing keel. I've used silicone, and the baggy filled water with zero results on both.....just '---' on display. The hull does have the roughness associated with laid up fiberglass. Some of the fibers stick 'this way and that' and present a rough surface. Should I sand these down with my palm sander and try again? I have tried the beeswax yet.
Diamondjet is offline
post #22 of 26 Old 04-26-2012
FWIW, when I installed a similar Garmin unit in my Pearson I could never get any of the test methods to work, eventually I just gave up and installed it properly, and it worked to 800' and that was with a 1 1/4" thick hull.
xymotic is offline
post #23 of 26 Old 04-26-2012 Thread Starter
sv Cordelia
Nicklaus's Avatar
I tried sanding it smooth and it didn't help...
Nicklaus is offline
post #24 of 26 Old 04-26-2012
Maine Sail's Avatar
Originally Posted by travlineasy View Post
Next, the position of the transducer should be relatively close to the stern, and about halfway between the keep and the waterline. This will provide you with a relatively flat location, which is the best you can hope for. Don't position the transducer close to the keep because part of the signal cone may be blocked.
Gary where do you come up with this stuff?
On sailboats Airmar, Raymarine and others recommend forward of the keel. I don't know a boat builder who has ever installed them aft of the keel though I'm sure some did..? Was on three different boats today alone, a C&C 110, Ericson & a Cape Dory all had the ducer in front of the keel ..
There is a nice black and white picture of where to mount it, in the Raymarine depth sounder installation instructions. The only time I see one aft is when a DIY was a previous power boater and they often have keel turbulence issues..
Even Uniden says this; (happened to have the manual in my shop next to me)
Uniden Depth Sounder Installation:
"On sailboats, mount the transducer where the acoustic beam will
not be shaded by the keel. A spot forward of a fin keel with a
minimum deadrise angle is preferred."
______
-Maine Sail / CS-36T
Maine Sail is offline
post #25 of 26 Old 04-26-2012
travlin-easy's Avatar
My old Catalina 27 with a fin keel was the second sailboat I fired the transducer through the hull. When I tried positioning the transducer forward of the keel it worked just fine when conditions were calm and the boat wasn't heeled hard. However, when the bay was a bit bumpy and the boat was heeled over the forward turbulence was such that the transducer could not read anything other than the bubbles. I repositioned the transducer to aft of the keel and under the same conditions no problems. I tested my newest Lowrance HD7's transducer at four locations on my Morgan 33, and again, the best results have been closer to the stern--not the bow. So, where do I get this stuff--practical experience.
Now, I've used other manufacturers depth finders in years past, Hummingbird, etc..., but my best readings while shooting through the hull have been when using Lowrance systems.
My best advice is to use whatever works best for YOU! This may take some work and experimentation, but you must keep in mind that every boat's hull is different, the power of the depth finders vary considerably, and the results will, obviously, vary. That's why we use things such as plastic bags, oil-filled reservoirs, etc.. to test the best position for the transducer.
Cheers,
Gary
travlin-easy is offline
post #26 of 26 Old 02-05-2013
jb1528's Avatar
I'm late to this discussion but wonder the best way to measure the deadrise angle given the boat rises perpendicular to the centerline and also fore and aft. At least that seams to be the case in my Bristol 32. I have an airmar transducer that was installed by the PO and question its positioning. Do you take the greatest angle and orient the base relative to that? What seems to be the consensus?
thanks
Jim
jb1528 is offline
Tags
depth finder , installation , shoot thru , transducer
Which In-hull transducer? 71Irwin32 Gear & Maintenance 2 02-22-2012 02:31 PM
Best in hull transducer Waltthesalt Electronics 3 03-25-2011 10:20 PM
Shoot thru hull transducer clarity36 Electronics 5 03-17-2011 11:12 AM
Through-hull transducer? flyingwelshman Gear & Maintenance 5 04-22-2008 12:27 PM
Thru Hull Transducer pixurman Gear & Maintenance 2 05-21-2002 08:04 PM
