Splits in stainless steel water tanks - SailNet Community
post #1 of 1 Old 04-25-2012 Thread Starter
Has anybody tried to seal stainless tanks inside with some kind of coating?
The tank is 25 years old, about 250 liters and is wide and flat in shape. The corners have split in several places. It is welded in under the floor framing in a steel yacht so inaccessible for welding. What about cutting the top out, taking out the baffles etc and putting in a flexible tank? Any other suggestions?
Erino is offline
Tags
flexible water tanks , water tanks
Stainless steel fastener set MarkSF Gear & Maintenance 3 05-23-2011 07:44 PM
Holding Tanks - Poly or Stainless??? HBBurlington Gear & Maintenance 14 04-11-2011 12:33 PM
Aluminum vs Stainless water tanks I33 Gear & Maintenance 13 06-13-2010 03:15 PM
Stainless Steel... merttan Gear & Maintenance 14 04-12-2008 08:59 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 04:46 PM
