Survey found corrosion in mast - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 08-20-2012
Re: Survey found corrosion in mast
Congrats on the new boat. The last one was trouble in the making. Enjoy sailing, instead of fixing!!
Jeanneau 54DS
Minnewaska is offline
post #12 of 14 Old 08-21-2012
Caribbean Surveyor
canadianseamonkey's Avatar
Catalina 30's are a dime a dozen...find one that doesn't have major issues. Run away from this one quickly. You'll be dumping money into this boat right away and you're sure to find other hidden issues as well as you get to know the boat.
canadianseamonkey is offline
post #13 of 14 Old 08-21-2012
Caribbean Surveyor
I should of read your last post...oops! Congrats on both decisions. Sailing is much more fun than sitting on the hard sweating your ass off working. Happy sails!
post #14 of 14 Old 04-30-2013
I know this post is old but just for the information: This type of corrosion is whats called filiform corrosion which is basically when water gets between the paint and the metal due to a scratch or ding in the paint. The aluminum starts to corrode because it cant re-passivate itself since its still under the paint and just corrodes from there. If the owner had seen the paint "bubbling" early, and stripped the paint the hole in the mast could have been prevented.
Also, this didnt happen from the mast having sitting water in it but water between the paint and the mast, probably due to a poor application of the paint or the preparation of the mast for paint. That being said, only the part of the mast that had the "bubbles" under the paint would need to be removed and assuming this hasn't happened anywhere else, the mast would be structurally fine. But a thorough inspection of the mast would need to be done since it was painted/prepped all at the same time.
Racecase is offline
mast step corrosion gweiser Gear & Maintenance 3 03-17-2012 10:08 PM
Mast Step Corrosion follysurf Gear & Maintenance 21 02-10-2012 08:52 PM
mast corrosion - how serious? pic attached tominny Gear & Maintenance 9 01-05-2012 03:35 PM
Survey found moisture in deck and cockpit dodgydingo Boat Review and Purchase Forum 26 07-20-2008 09:39 PM
Mast Corrosion? greencaptn Gear & Maintenance 3 07-09-2007 04:11 PM
