Pump Faucet No Worky - SailNet Community
 4Likes
post #1 of 23 Old 04-25-2012 Thread Starter
rbrasi's Avatar
I've had this boat for a year and never cared to figure out how to work this vanity sink. I pump the lever, but nothing happens. I unscrewed the spout and poured water in there to prime it and it went everywhere except out the faucet. What gives? The feeder line runs to the freshwater holding tank. As far as I know, there is not a valve there. Can something this simple be broken? Operator Error, maybe?
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #2 of 23 Old 04-25-2012
Re: Pump Faucet No Worky
Many of those faucets have a valve that can be changed from tank to raw water. Does yours? Typically found somewhere under a galley or head floor.
Jeanneau 54DS
Minnewaska is offline
post #3 of 23 Old 04-25-2012 Thread Starter
rbrasi's Avatar
The hose runs through a bulkhead down below the vanity. I'll trace it after that.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #4 of 23 Old 04-25-2012
Check for a broken line while you trace as well. However, if you find the valve, it could be set to raw water on a through hull that is closed.
Jeanneau 54DS
post #5 of 23 Old 04-25-2012
JimsCAL's Avatar
Did it work before and now has stopped working, or did it never work? The valves in those things can go bad, and need to rebuilt or replaced.
JimsCAL is offline
post #6 of 23 Old 04-25-2012 Thread Starter
rbrasi's Avatar
The PO told me it worked and needed to be primed when I bought her. I have no reason to doubt it, as everything else he said was true. I'll check when I'm aboard tonight.
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #7 of 23 Old 04-26-2012
It's not uncommon to have to pump a dry faucet several times before getting water, but I've not had to prime one before. Perhaps it was failing for the prior owner and the priming was just a band aid.
Jeanneau 54DS
post #8 of 23 Old 04-26-2012
Senior Slacker
SlowButSteady's Avatar
If possible, I would just replace that pump with one that is foot-operated.
They tend to be more robust, priming is less of a concern since they are located close to or below the level of the tank, and you can actually hold BOTH your hands under the faucet while the water is running. The biggest drawback I've found is that my 4-year-old is totally fascinated with them (she can go through 20 gallons in no time if I let her).
chef2sail, zeehag and Minnewaska like this.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #9 of 23 Old 04-26-2012
72 C&C Corvette
CorvetteGuy's Avatar
I believe there is a diaphram inside that hand pump, when it cracks or drys out no workky. I have the same one and it hasnt worked in years. but i'v also had a replacement for years but never got to installing it.
CorvetteGuy is offline
post #10 of 23 Old 04-26-2012
JimsCAL's Avatar
Shouldn't need to be primed. Replace it.
zeehag likes this.
JimsCAL is offline
vintage faucet? amyspins General Discussion (sailing related) 17 01-21-2012 06:45 PM
Hot water spurting from faucet--causes? josrulz Gear & Maintenance 8 10-26-2011 07:47 PM
"pressure" water/ jabsco gravity pump faucet combo TBG P30 0 07-30-2011 12:25 PM
Galley faucet NonaCat22 Gear & Maintenance 0 06-23-2011 04:20 PM
Water filter with manual pump faucet? IslanderGuy Gear & Maintenance 7 12-24-2009 08:06 AM
