Please critique my charging schematic - Page 3 - SailNet Community
 1Likes
post #21 of 30 Old 04-30-2012
Skipper Jer's Avatar
Re: Please critique my charging schematic
While eyes are focused here, I've got a couple questions. I noticed that there is a switch position that connects the two batteries in parallel. If one battery is discharged while the other is fully charged and the switch is put into both, would the current flow be dangerous? Why not just diode isolate the two batteries for charging purposes? Diodes are a few dollars each, the echo device is ~$100.00.
Skipper Jer is offline
post #22 of 30 Old 04-30-2012
Learning the HARD way...
eherlihy's Avatar
I'll toss another schematic at you. Everything here works;
eherlihy is offline
post #23 of 30 Old 04-30-2012
eherlihy's Avatar
Here - in living color - are the ABYC Color Code recommendations;
You CAN vary from this, as long as it is documented, and still be ABYC compliant.
Also, yellow is the preferred color for DC negative, so that you don't mix it up with AC hot.
eherlihy is offline
post #24 of 30 Old 04-30-2012
eherlihy's Avatar
The fuse types on the batteries in the above schematics are these;
eherlihy is offline
post #25 of 30 Old 04-30-2012
"There is the same fault indicator that a Blue Seas breaker has - it shuts off. "
Well, yes, but we expect a breaker to be a breaker. These look like the common lighted 12-volt switches made, sold, used, by many sources. There's no way (from the picture) to tell that these are breakers, instead of the common lighted switches, is there?
meme-
An echocharger isolates the batteries while consuming very little power. A diode isolator consumes about 1/2 volt all the time, so you are wasting power. They're cheap but they're inefficient.
And yes, paralleling one good battery with one bad one will pull down the good one until they equalize. Not necessarily dangerous but a good way to kill your good battery.
hellosailor is offline
post #26 of 30 Old 05-01-2012
mitiempo's Avatar
The Echo Charge is a good choice as it will not allow overcharging of the start battery.
The parallel switch, as you say, should not be used to combine a discharged with a charged battery. A neighbor of mine did exactly this yesterday and his charged start battery combined with his pretty discharged house bank (8 golf carts in series/parallel) left him dead in the water.
The parallel switch allows you to charge both banks in the unlikely event of an Echo Charge (or ACR) failure.
Brian
mitiempo is offline
post #27 of 30 Old 05-01-2012
mitiempo's Avatar
They definitely are low budget breaker panels, but serviceable as far as I can tell. The description in the West Marine catalog describes them as Carling breakers. I was skeptical when my customer showed it to me last week.
The 6 breaker panel is only $49.
I really prefer Blue Seas panels. But their 6 breaker DC panel is around $200
Brian
mitiempo is offline
post #28 of 30 Old 05-01-2012
mitiempo's Avatar
I don't think many follow this though - I've never been on a boat with it as far as I can remember.
I'm just happy when they have used red for positive and black for negative - it seems many don't go that far.
Brian
mitiempo is offline
post #29 of 30 Old 05-01-2012 Thread Starter
or, it allows me to start off the house bank by switching the ON/OFF to OFF and the 1/2/BOTH/OFF switch to BOTH!
sfbaysailing is offline
post #30 of 30 Old 05-01-2012
mitiempo's Avatar
Yes it does.
I have 2 separate switches - one for start and one for house - without a crossover option. Maine's solution allows for that.
Brian
mitiempo is offline
S2 7.3 battery charging Lflowers230 S2 0 01-16-2012 12:31 PM
Critique this mooring setup! dvuyxx Gear & Maintenance 12 04-26-2010 09:04 PM
New wiring diagram- please critique! funjohnson Electrical Systems 33 03-23-2010 07:45 PM
Wiring Schematic for boat electronics billbalme Pacific Seacraft 1 03-07-2010 07:43 AM
Battery charging... merttan Gear & Maintenance 17 06-23-2008 04:04 PM
