Butane stove - SailNet Community
post #1 of 11 Old 04-26-2012 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Butane stove
Does anyone have any experience using a butane stove onboard? I just don't want to use my pressurized alcohol stove anymore.
I have a double burner, GasOne stove that uses locked in cannisters. Each can can run 2-8 hours.
Severna Park, MD
Pearson 35 - s/v Tiger Lily
dvuyxx is offline
post #2 of 11 Old 04-26-2012
Re: Butane stove
Have used the "korean bbq" restaurant specials many times on a number of boats. If used with some respect for explosive gasses, no problem, they work very well. $20 including case and if it rusts in five years, buy a new one.
If used without proper safety precautions...the gasses still explode in the proper manner, and all that good stuff.
But hell yes, I'd rather use butane that any kind of alcohol. I'd rather eat cold food or no food than use alcohol.
hellosailor is offline
post #3 of 11 Old 04-26-2012 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Re: Butane stove
Good points. I'm looking forward to using this unit. Thanks
Severna Park, MD
dvuyxx is offline
post #4 of 11 Old 04-27-2012
Sundance 23
carl762's Avatar
Re: Butane stove
I use one of the Korean Restuarant cheapies as a backup. Works great.
Water is Life
carl762 is offline
post #5 of 11 Old 04-28-2012
T37Chef's Avatar
Thumbs up Re: Butane stove
I've cooked for hundreds using these butane stoves, love em. Cheap, easy to use, and do the job. We had one on our previous boat and used it often, but never underway, only at anchor or dock.
If you're looking for a reliable, safe, and cheap way to cook aboard, I don't think you could find anything better.
Shawn
T37Chef is offline
post #6 of 11 Old 04-28-2012
sailguy40's Avatar
Re: Butane stove
I have one I purchased at academy sports which is very similar to this...
http://www.amazon.com/Portable-Butane-Stove-With-GASONE/dp/B001V72U36/ref=sr_1_13?ie=UTF8&qid=1335669720&sr=8-13
I use it in my galley. It works very well and I am completely satisfied with it.
sailguy40 is offline
post #7 of 11 Old 04-28-2012
JimsCAL's Avatar
Re: Butane stove
Nothing wrong with a non pressurized alchohol stove like an Origo. The major issue is the cost of the fuel. Shop around for alchohol and butane cylinders and it may be a wash. West Marine prices for both are crazy. I've had good experience with an Origo fueled by denatured alcohol from the local hardware store and have no problem doing that again.
JimsCAL is offline
post #8 of 11 Old 04-29-2012
Dirt Free
boatpoker's Avatar
Re: Butane stove
You may wish to check with your insurance broker and ask if using one of these would void your insurance as they do not have thermocouples and it is unlikely that you have a proper LPG storage locker.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #9 of 11 Old 04-30-2012 Thread Starter
s/v Tiger Lily
dvuyxx's Avatar
Re: Butane stove
What is the general safety/danger storing those butane cartridges. Is the purpose of the exterior storage locker to prevent gas buildup or to get it away from heat sources.
Severna Park, MD
dvuyxx is offline
post #10 of 11 Old 05-01-2012
Re: Butane stove
The problem with storing combustible gases below, especially those heavier than air, is that they may leak. The containers are not very robust. If they leak, the gas builds up in the cabin or the bilge, and with one spark, it does what a combustible gas is supposed to do: Blow you to kingdom come.
So "proper" safety precautions include using a gas detector, a blower, and storing the gasses in a properly sealed and vented locker, so that if there are any leaks the gas vents overboard.
Cheap Butane stove fuel cans!!! MacGyverRI Provisioning 14 04-14-2011 08:49 AM
Propane, butane, CNG Yofy Cruising & Liveaboard Forum 13 11-11-2007 12:42 PM
Butane to Propane conversion Ovniman Gear & Maintenance 5 07-31-2005 05:50 AM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 08:00 PM
From Propane to Butane John Kretschmer Cruising Articles 0 09-23-1999 08:00 PM
