Good diameter Amsteel for lifelines - SailNet Community
post #1 of 3 Old 04-26-2012 Thread Starter
Irunbird's Avatar
I'm swapping out my wire lifelines for Samson's Amsteel on our Olson 30. I've read the IASF regs, and this is at least Cat 3 compliant for monohulls, and I think Cat 1 as well. Most of the boats in my class are using 3/16", but I'm wondering if 1/4" might be better handling... It also would probably last longer, especially if you shield the portions running through the stanchions. Has anyone got any experience with the same issue about line size?
Ray
Irunbird is offline
post #2 of 3 Old 04-26-2012
Liquorice's Avatar
Re: Good diameter Amsteel for lifelines
The smallest dia you can buy is probably strong enough to lift your boat!
So it's not strength that's the limiting factor but other, secondary stuff like cost; colour; thickness cutting through your chest on a beat; etc..
sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #3 of 3 Old 04-26-2012 Thread Starter
Irunbird's Avatar
Thank you, Sam- I figured the old stuff was 1/8", so how bad can almost 1/4" be (3/16")?? The local West Marine has it in stock, but would have to order the 1/4", so it was an easy choice. I'll figure out how to do Brummel splices this weekend x 4!
Ray
Irunbird is offline
PSC34. Sterntube Diameter. YankeePSC34 Pacific Seacraft 1 02-15-2012 06:35 AM
Cal 2-29: Diameter of Running Rigging?? Arch_NME Cal 10 05-23-2010 04:54 PM
Barient 28 base diameter Polypterus Gear & Maintenance 5 04-02-2010 07:09 PM
Lifeline attachment alternatives, amsteel lines. zz4gta Gear & Maintenance 14 09-30-2008 08:02 PM
Correct forestay diameter? wysiwyg Gear & Maintenance 8 04-15-2007 06:02 PM
