Best suggestion for adding 100 lbs to the anchor locker - SailNet Community
 9Likes
post #1 of 26 Old 04-27-2012 Thread Starter
I would like to add approx 100 lbs to the anchor locker, to make the boat sit on it's lines. The weight is needed thanks to the two extra batteries added to the lazarettes, and the removal by a PO of a large amount of anchor chain.
Any suggestions for actually adding it? Where can you buy large lumps of iron?
My local sports store has 50 lb hand weights for about $50 each, so far that's my best plan.
MarkSF is offline
post #2 of 26 Old 04-27-2012
Old as Dirt!
svHyLyte's Avatar
Re: Best suggestion for adding 100 lbs to the anchor locker
Why not an appropriate length of chain to get some use out of the extra weight. (Or better yet, relocate the batteries to get a better/more sensible weight distribution and out of the yacht's ends. Think of "Pendulum Action" with weight in the ends. AKA, "How strong is your stomach in a seaway?")
FWIW...
svHyLyte is offline
post #3 of 26 Old 04-27-2012
Courtney the Dancer
jrd22's Avatar
Just adding weight seems like a waste. Why not replace the anchor chain that was there before so you have better ground tackle as well as trimming the boat?
edit: Ha! you beat me to it Hy
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #4 of 26 Old 04-27-2012
asdf38's Avatar
Add another anchor or get more chain. Or store lots of heavy junk (water bottles) in the V-birth. I'd be loathe to actually add balast to the boat high and up front.
If you do add weight try to keep it low. Perhaps under the V-birth? If you can get it below the waterline at least you'll get some additional benefit from it.
EDIT: Never mind, not quite right.
asdf38 is offline
post #5 of 26 Old 04-27-2012
I think , the PO of my old Bristol 29 had placed 2 bars of iron in the forepeak for that same purpose. The Weights would work, and not take up much room.
I keep a 10 gallon jerry jug of Diesel in the anchor locker on my sabre when on a trip, and a collision mat.
IF you had the room, you could keep 12 gallons of fresh water up there in a couple of solid jugs. Water weighs 8 lbs/ gallon. (96 lbs. ) and it's useful.
tempest is online now
post #6 of 26 Old 04-27-2012 Thread Starter
Right now there's 20 ft or so of chain. Would there be any significant advantage to extending that? A quick look online showed 90ft lengths of chain with the correct weight, roughly. Bear in mind there is no windlass (yet)
MarkSF is offline
post #7 of 26 Old 04-27-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Have to agree with the others. Why waste it. Add chain to assist your anchoring security.
As for the nitpick ASD, reducing weight above the waterline is usually good for overall perfomance but certainly better to level out the boat than not.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #8 of 26 Old 04-27-2012
A boat can be taken as acting through the centre of gravity as in effect a balance point, however weight in the ends does have an effect on pitching through angular momentum presumably and the length of the moment from the cog.
If you have sufficient chain then the best approach to the stern being too heavy is to move the batteries amidships or over the cog, then you don't have to add any weight. If that is not possible then the least balancing weight will be forward but that will increasse pitching.
chris_gee is offline
post #9 of 26 Old 04-27-2012 Thread Starter
Well I have just sufficient chain but could extend it if there's a worthwhile advantage. I take it chain is more secure but the disadvantage is the work required to raise the anchor?
Another option is to buy 12 of 1 gallon water bottles from the supermarket, distribute them about the V berth lockers, anchor locker, and maybe even get a few under the V berth but it's pretty tight under there with a water tank.
MarkSF is offline
post #10 of 26 Old 04-27-2012
At least 2x your length in chain is recommended, mainly as a catenary for better anchoring. So that gives you another 50' or so. A windlass helps but you are only lifting in maximum at a time the weight of chain at the depth you are anchored at plus the anchor weight. If you fish in 70' using that anchor and chain you have quite a heave, anchoring in 20 feet not so much.
E32 anchor locker mod Ritchard Endeavour 2 07-09-2012 08:24 AM
Anchor chain ... locker micheck Cal 4 06-15-2011 06:31 PM
Anchor Locker Renovation QuickMick Gear & Maintenance 2 08-26-2010 04:53 PM
Anchor Locker Drain playinthru08 Gear & Maintenance 8 09-01-2008 01:19 PM
hinge oem - anchor locker oday25maine Gear & Maintenance 2 10-24-2004 04:57 PM
