Catalina 30 Bahama bound - SailNet Community
 5Likes
post #1 of 13 Old 04-29-2012 Thread Starter
db27513's Avatar
I have a '89 30ft Catalina (wing keel, standard rig) based in NC that Im considering taking to the Bahamas. I have a list of modifications to make, but since Im hauling out in a week or so, I want to modify the undercarriage.
The rudder is a skegless spade rudder, and with the wing keel, draws only 6" less than the keel (kind of exposed to groundings IMO). My thought is to place a wire cable or strap between the aft part of the keel, and the bottom of the rudder exactly on its turning axis. This would help prevent debree from floating into the cavity between the keel & rudder, and hopefully prevent things from getting tangled on the strut/prop and in the crease between the rudder and the bottom of the boat, as well as give the rudder additional support in a grounding. Same concept might apply to placing a wire cable between the leading edge of the keel and the bow..
Has anyone done anything like this?
Dave in NC aboard Sugar Too
db27513 is offline
post #2 of 13 Old 04-29-2012
scurvy dog
delan's Avatar
Re: Catalina 30 Bahama bound
it will collect a lot of sea grass
Restauranteur
Mako 236
Shamrock 26
Schucker 44 Cutter
Dyer Dhow
delan is offline
post #3 of 13 Old 04-29-2012
ebs001's Avatar
I see no advantage doing this and if it were a good idea someone would have done this along time ago.
blowinstink and Group9 like this.
ebs001 is offline
post #4 of 13 Old 04-29-2012
snider's Avatar
The water is so very clear there I wouldn't be worried about it. As for the trip down again I wouldn't worry, personally. I think its a waste of time. If you hit something hard enough to damage the rudder is that cable going to stop it, also with it being attached to the rudder it's still going to pull on the rudder. I'd spend my time on something else. Enjoy your trip.
blowinstink likes this.
Brandon
Charleston SC
Starwind 223 & Compac 16
snider is offline
post #5 of 13 Old 04-29-2012
I would spend the money, on something else important instead. If you are really worried about the rudder, buy a transom mount spare.
I second the above, the cable isn't going to keep your rudder from getting tweaked in a grounding. It also will not give any lateral support to rudder either in case of a grounding or severe stresses in a storm.
The full keel in front of the rudder is what makes it strong.
Remember both the cable, and the attachment points have to be able to hold the full weight of the boat. BY the time you had enough cables to do that your under water drag would be considerable.
I also have a spade rudder, I bought a spare rudder with mounting for the transom that I keep under a bench cushion where it takes up no room. SO far I have never needed it. (knock on wood)
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #6 of 13 Old 04-29-2012
Send a message via Yahoo to dacap06
I don't know about you, but I have enough problems with water intrusion in my rudder as it is. I wouldn't want to put a screw in the bottom of mine.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #7 of 13 Old 04-29-2012
72 C&C Corvette
CorvetteGuy's Avatar
Dont do it. for many reasons as said previously. happy saylin
CorvetteGuy is offline
post #8 of 13 Old 01-22-2014
Bon Voyage!
pforeman98 is offline
post #9 of 13 Old 01-22-2014
Have fun! I commend you on your bravery. Reading what some say here on SN you are taking your life into your own hands by taking a Catalina, Hunter, Bene any farther than the deep end of your swimming pool! Hahahaha!
stinson6 is offline
post #10 of 13 Old 01-22-2014
Glad I found Sailnet
Bene505's Avatar
I'd spend the money on an AIS transponder. The nastiest things to hit are the ones made of steel.
Barring that, solar power, watermaker and reinsulating the fridge/freezer with aerogel/cryogel.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
Compare/Contrast Catalina 30 & Islander Bahama 30 SailingLazy Boat Review and Purchase Forum 10 06-28-2012 09:01 PM
Bahama bound smillinjack General Discussion (sailing related) 2 01-08-2012 05:51 PM
Islander Bahama 24 or Catalina 25 Music_man Introduce Yourself 2 01-07-2012 12:32 PM
catalina 22/bahama 24 pithwit Boat Review and Purchase Forum 1 06-01-2006 12:13 AM
Bahama''s Bound and need help! john_fennessy Cruising & Liveaboard Forum 10 02-21-2002 01:39 PM
