stuffing box de-packed several questions before re-assembly - Page 2 - SailNet Community
post #11 of 15 Old 04-30-2012
Señor Member
PorFin's Avatar
Re: stuffing box de-packed several questions before re-assembly
Rhapsody -- I'm with MiTiempo on this one. The patina you see is quite normal, and unless you've got dezincification issues, the box is probably fine.
Be careful using the PB Blaster around anything rubber, since it'll eat it for lunch.
If you're determined to replace the box, think about investing in a dripless system like the PSS. We are really pleased with ours.
PorFin is offline
post #12 of 15 Old 04-30-2012
Daniel - Norsea 27
Rhapsody-NS27's Avatar
Thanks for the suggestions. I'll get a couple wrenches to work on this and see how things go. I'll look into PSS another time but will plan to repack to be sure its update is current.
~Dan
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is online now
post #13 of 15 Old 04-30-2012 Thread Starter
johnnyandjebus's Avatar
Hello all
Thanks for the replies,
I was able to get the stuffing box stuffed 5/16's was too big and 3/16's too small so 1/4 it was.
I still need to tighten up the backing nut. The main nut holding the flax is hand tight, no wrench. Does this sound right?
As well when I manually turned the shaft after the fact I heard a rubbing sound, nothing dramatic but it was there. Does this indicate that the flax is in tight and rubbing against the shaft? Hard question to answer I know.
I confess that I am a little nervous about launch day, as this is the first time I have done this. But logically the flax is bedded well and appears to be a nice fit so nothing to worry about I guess.
John
"The more I know about people, the better I like my dog."
-- Mark Twain
"If you can’t explain it to a six year old, you don’t understand it yourself.”
--Albert Einstein
johnnyandjebus is offline
post #14 of 15 Old 04-30-2012
Tartan 27' owner
CalebD's Avatar
You should be fine JnJ.
Just keep your wrenches on your boat in case you need to tighten (or loosen) the packing gland once in the water. The first thing you check on your boat after launch is your stuffing box once you have messed with it.
You will need to monitor your stuffing box with the engine engaged as well. If the stuffing box gets hot then it needs to be loosened. There should be a few drips of water per minute with flax packing - is that what you used?
Everybody has one:
CalebD is offline
post #15 of 15 Old 05-01-2012
Junior member, rest old
msmith10's Avatar
No need to be nervous. At worst, an very unlikely, even if you have to repack it that can be done in the water.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
Items wish you had packed more of ncapener Provisioning 6 02-26-2012 04:03 PM
Sailboat packed with Haitians capsizes, 58 missing - HULIQ NewsReader News Feeds 0 05-07-2007 08:15 PM
Sailboat Packed with Haitians Capsizes, 58 Missing - Javno.hr NewsReader News Feeds 0 05-07-2007 04:15 PM
Sailboat packed with Haitians capsizes - Reuters.uk NewsReader News Feeds 0 05-07-2007 02:15 PM
Sailboat Packed with Haitians Capsizes, 58 Missing - Javno.hr NewsReader News Feeds 0 05-04-2007 05:15 PM
