coolant for yanmar diesel? - SailNet Community
 3Likes
post #1 of 18 Old 04-29-2012 Thread Starter
NewportNewbie's Avatar
Being this is my first diesel engine I want to be sure. I need to add coolant. It's green coolant. Is that normal automotive coolant? I would imagine yes. My buddy who has a yanmar diesel brought some pink coolant and said his uses that. Can I mix green and pink? I know with my BMW I can't mix green and blue. It's one it the other. Thx!
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 18 Old 04-30-2012 Thread Starter
Found the info. Pink and green don't mix and yanmar has stated the green coolant can break down the cylinder walls. Red coolant is what's supposed to be used.
post #3 of 18 Old 04-30-2012
Re: coolant for yanmar diesel?
Ever since a mechanic showed me some gelatinized coolant from a motor that had mixed coolant types, I've been paranoid. I don't know which combo will do that, which makes me more paranoid.
Drain it and start from scratch. Coolant should be replaced periodically anyway. Manuals usually say annually.
Jeanneau 54DS
Minnewaska is offline
post #4 of 18 Old 04-30-2012
Irrationally Exuberant
My 2GM20F came with green in it. Don't know how long it was like that. When I finally got around to replacing, I drained what was in there and used Prestone Extended Life, which is green. If this is bad, then I guess it has been bad for a while.
Still I think this isn't just a matter of antifreeze color--even the pinks aren't all the same. Wouldn't mind hearing the definitive word on this.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #5 of 18 Old 05-07-2012
So no Yanmar mechanic or other expert is going to weigh in on this?
Tom K
2000 Beneteau 331
arf145 is offline
post #6 of 18 Old 05-07-2012
Tim R.'s Avatar
I can tell you after speaking to a Yanmar mechanic and reading the manuals, anything other than what Yanmar specifically recommends voids the warranty.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #7 of 18 Old 05-07-2012
I'm not too worried about the warranty on my 25-yr-old engine. And I wonder if the recommendations in my 25-yr-old manual might have changed just because of changes in the products/technology out there. Does Yanmar publish current recommendations for older engines?
Jgbrown likes this.
Tom K
2000 Beneteau 331
arf145 is offline
post #8 of 18 Old 06-15-2015
I have a yanmar 2GM20F - my first diesel engine (my first boat actually). I need to add coolant. I know that I need to change the coolant completely and choose either red or green.
But my question is this: if at this time I only want to add coolant, can I do that? Or do I have to drain everything? If I can just add some to get me through the summer before I drain it all at the winter, what kind can I add? (currently there is green). Or can I just add water?
I only motor about 15 minutes at a time (15 to get out of marina and 15 to get in) and I only sail about 2-3 times a week. Is it ok to wait to drain and put in all new coolant this winter and simply add some for the time being?
Thanks !
dbw_kairos is offline
post #9 of 18 Old 06-15-2015
Shell Dex Cool Extended Life 50/50
dbw_kairos likes this.
aa3jy is offline
post #10 of 18 Old 06-15-2015
Skipper Jer's Avatar
Yanmar has their own brand of coolant: YANMAR Ultralife YG30.
In the advisory ( http://portal.mastry.com/bulletins/M...i%20Freeze.pdf) they go on to say Mr. Goodwrench Texaco and Shell meet the requirements.
Another bulletin ( http://ldmarineservice.com/files/yanmar_bulletins.pdf ) approved Texaco Long Life Coolant, Havoline Extended Life, Dex-Cool and Prestone Extended Life.
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
The Following User Says Thank You to Skipper Jer For This Useful Post:
Hush34 (01-03-2017)
Yanmar 4JH-2E using coolant Tim R. Diesel 7 12-06-2013 12:09 PM
Yanmar losing coolant Tim R. Diesel 5 07-02-2013 09:54 PM
yanmar coolant draincocks sailor1950 Diesel 0 04-08-2012 03:07 PM
Yanmar YM coolant leak ctlow Diesel 3 06-11-2011 06:30 AM
Yanmar coolant replacement Norstar Pacific Seacraft 8 11-11-2009 09:47 AM
