Electric head - repair or replace w/manual - SailNet Community
View Poll Results: new motor or new head
Motor 1 16.67%
New manual head 5 83.33%
Voters: 6. You may not vote on this poll
post #1 of 10 Old 04-30-2012 Thread Starter
jsaronson's Avatar
Should I spend $125 for a new motor for my Jabsco electric head or $170 for a new manual unit?
The motor must have a bad spot on it. When it does not work I rotate the shaft with pliers and it spins properly.
jsaronson is offline
post #2 of 10 Old 04-30-2012
Learning the HARD way...
eherlihy's Avatar
Re: Electric head - repair or replace w/manual
100% of the poll respondents say replace with a new manual head...
Any questions?
eherlihy is online now
post #3 of 10 Old 04-30-2012
Maine Member
BELLATRIX1965's Avatar
Any questions?
Yup, 100% of respondents STILL say manual! K.I.S.S.
BELLATRIX1965 is offline
post #4 of 10 Old 04-30-2012
Replace with VacuFlush. I'm waiting for an excuse.
Jeanneau 54DS
Minnewaska is offline
post #5 of 10 Old 04-30-2012
eherlihy's Avatar
Here is one excuse... $4K+ installation
I happen to have a Vacuflush system, installation paid for by the PO... While I'm OK with it, I can't see forking over 4 boat bucks for one...
post #6 of 10 Old 04-30-2012
What? Gold plated maybe. Here is a randomly googled one for $500. You also need the vacuum generator, which is less, then installation.
Vacuflush 5000 Series
Jeanneau 54DS
post #7 of 10 Old 04-30-2012
VacuFlush means no salt water in holding tank or bowl to smell, clear waste lines, less water to flush means way more holding tank capacity. All pluses, albeit, they are more expensive.
Jeanneau 54DS
post #8 of 10 Old 04-30-2012
eherlihy's Avatar
I like the system
However the toilet above is $500
I found a vacuum generator (refurbished) for $750 hereVG2 REFIRBISHED - Seacoast Services, Inc. (per the same website a new one runs $1172.00)
then you need a holding tank ~ $200
Then new hoses... ~$100
I'm at $1500 + installation so far, and that is for a re-furb toilet. New would easily be over $2K...
So I'll concede that $4K plus install was high. However $4k for the system installed is about right.
I don't mean to speak for the OP, but he is debating whether to spend $125 for a motor, or $175 for the head itself. I'm just guessing here, but $2K is probably out of the question.
post #9 of 10 Old 04-30-2012
I do not believe you need a new holding tank, unless you buy the integrated vacuum pump and holding tank. You may or may not need new lines.
They are more expensive, just not nearly what you suggested above. They also seem quite worth it and get benefits you can't have with traditional heads, manual or electric.
Jeanneau 54DS
post #10 of 10 Old 05-01-2012 Thread Starter
jsaronson's Avatar
Thanks
Atlantis
Hylas 44
Annapolis
Tags
electric , head , toilet
Replace Atomic 4 with Electric Motor? Wannafish Gear & Maintenance 29 05-13-2011 09:46 AM
Head - electric conversion or new electric head snw Gear & Maintenance 5 04-29-2007 07:07 AM
Lighthouse 1501 Electric/Manual Windlass? capecodphyllis Gear & Maintenance 8 03-01-2007 04:18 AM
Manual to Electric Fuel Pump flintda Gear & Maintenance 2 02-20-2006 12:39 PM
Electric Head Repair wwilson Gear & Maintenance 2 09-10-2004 02:31 AM
