Battery charging question - SailNet Community
post #1 of 3 Old 05-01-2012 Thread Starter
If I have my two house batteries in parallel do I need to connect both to the charge source, ex. Both batteries + and -, from solar and shore charging sources, or just on one battery and both will charge because of paralleling?
Dolby is offline
post #2 of 3 Old 05-01-2012
mitiempo's Avatar
Re: Battery charging question
You only need 1 positive and one negative connection. Parallel batteries act as one, no matter how many in the bank.
The best way for all connections to be made is the negative of one battery and the positive of the other. This both charges and draws evenly from each battery. If you make the connections only on one battery it will see the greatest load and the most charging.
Brian
mitiempo is offline
post #3 of 3 Old 05-01-2012 Thread Starter
Perfect! That's what I was thinking but I just needed some reassurance.... Thanks brian
Dolby is offline
HELP: Battery Charging Question pprimont Electrical Systems 16 08-25-2009 01:06 PM
Charging Battery netscheid Gear & Maintenance 19 04-22-2009 01:28 PM
Battery Charging labatt Gear & Maintenance 22 02-17-2009 10:50 PM
Battery Charging Question seapadrik Gear & Maintenance 7 06-06-2007 01:16 AM
Battery Charging Question gwp Gear & Maintenance 6 05-07-2004 11:28 PM
