Replacing V berth foam material - Page 3 - SailNet Community
 2Likes
post #21 of 36 Old 05-08-2012
jimrafford's Avatar
Re: Replacing V berth foam material
We just picked some up from Job Lot.
Jim
S/V Deja Vu
CS 40
jimrafford is offline
post #22 of 36 Old 05-08-2012
I use several layers of thick carpet covered by Sampson PVC saturated dacron. It's the only thing which wont hurt my back and wont absorb water. I gave up on fabric 40 years ago. No complaints from me or my crews.
Brent Swain is offline
post #23 of 36 Old 05-08-2012
BMLipiec's Avatar
Last year we replaced the v-berth mattress after we had a catastrophic holding tank leak - the clean out deck plate located beneath the mattress loosened while bashing home one day. Nasty. The mattress was a complete loss and had to be replaced.
Additionally, we added a memory foam topper, and bought a Froli sleep system (snap together spring affair) to install under the matress. It made all the difference, and I highly recommend it.
Brian & Marya
S/V Indigo
Pacific Seacraft 34
Hull #281
BMLipiec is offline
post #24 of 36 Old 05-10-2012
Originally Posted by Minnewaska View Post
Anyone have a source for a high quality dense memory foam topper? The thicker the better. We have an old inch and a half to tow inch topper that does little more than give the illusion.
Costco. Only thing I've ever bought there other than candy. 150$ long warranty
Jgbrown is offline
post #25 of 36 Old 05-13-2012
Sabreman's Avatar
JoAnn Fabrics has high density in 1, 2, 3, 4, & 5" thicknesses.
Sabre 38 "Victoria"
Sabreman is offline
post #26 of 36 Old 05-14-2012
WinterRiver's Avatar
If buying at JoAnn Fabrics, there are almost always coupons available for 40% off any single non-sale item. Makes a big difference.
WinterRiver is online now
post #27 of 36 Old 05-14-2012
I only see it in 2 ft wide strips. Can you get it wide enough for a full size berth?
Jeanneau 54DS
Minnewaska is offline
post #28 of 36 Old 05-14-2012
JimMcGee's Avatar
Re: Memory Foam -- Be Careful
Originally Posted by travlineasy View Post
I'll probably go with some 4-inch memory foam in the near future ...
Be careful about investing in enough memory foam to do you berth cushions. We purchased a memory foam bed for home thinking it would help with back pain as claimed. These things are shockingly expensive.
After six months we just gave it away. By then I was sleeping on the floor to get relief for my back and my wife was in constant pain.
I asked my doctor about this and he explained that you sink into memory foam and it tends to inhibit your turning over in your sleep and that leads to muscle cramps in your back and can also aggravate disk problems. His attitude was along the lines of "yep, another memory foam problem".
We went back to a firm mattress and went back to the normal, occasional middle aged back pains
I have talked to some people who like memory foam, but a lot more who had similar problems. The majority of the "likes" have been from people under 40.
We haven't tried a memory foam topper over standard cushions. But memory foam tends to hold heat, which wouldn't be a good thing on a humid night.
As always YMMV
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #29 of 36 Old 05-14-2012
JimMcGee's Avatar
We had our cushions professionally done. The material on top is a soft furniture fabric supplied by the canvas maker. The bottoms are phifertex to help the cushions breathe. She recommended a "medium firm" foam.
One item that I haven't heard mentioned is the need to back cut the cushions so they fit snugly against the curve of the berth so there's no gap for you or for things to fall into. We also took her two sets of sheets my wife picked out and had her make fitted sheets.
v-berth
Aft Berth
I'd still like to try the Foli system under these cushions.
JimMcGee is offline
post #30 of 36 Old 05-14-2012
We have a temper-pedic mattress at home and have trouble sleeping elsewhere now. It isn't for back trouble, but for me, its my shoulders. Arthritis, I believe. My wife's arm falls asleep when we sleep on hotel mattresses. Yes, they are expensive. I've been told there are those that love them and those that hate them, and no one in-between. I think that is true.
We have a 2 inch very soft topper on our berth on the boat. We would like to find something much thicker. The mattresses aren't bad, so I'm convinced a better topper and we're set.
Still having trouble sourcing a thick dense topper that will fit a queen size bed. The two inchers are everywhere.
Jeanneau 54DS
Replacing foam on couches and V berth MarkSF Gear & Maintenance 5 09-09-2011 08:40 PM
Replacing V-berth wall panels P36-2 hoppy Pearson 3 02-15-2011 08:57 PM
drycleaning foam? marcusn Gear & Maintenance 7 03-06-2008 12:27 PM
replacing foam in berth cushions wumhenry Gear & Maintenance 14 09-13-2007 11:55 AM
FORWARD HATCH-REPLACING WITH CLEAR TINT MATERIAL naturechick23 General Discussion (sailing related) 6 08-16-2004 11:08 AM
