Replacing V berth foam material - Page 4 - SailNet Community
 2Likes
post #31 of 36 Old 05-14-2012
Sabreman's Avatar
Re: Replacing V berth foam material
JoAnn Fabrics only has 24" wide sections. I simply glued widths together to get what I needed. Professionals routinely glue sections. Using the right spray glue will yield a perfectly strong joint. I've never had one fail.
Sabre 38 "Victoria"
Sabreman is offline
post #32 of 36 Old 05-14-2012
No one has ever accused me of being professional.
What spray glue did you use?
I did find a couple of 4" thick topper online, however, mostly from places I've never heard of. One exception was Walmart, although, not available in the store and they can buy junk to get the price.
I was hoping to be able to buy from a reputable place or be able to check it out myself. There is a JoAnn fabric nearby.
Jeanneau 54DS
Minnewaska is offline
post #33 of 36 Old 05-14-2012
Sabreman's Avatar
I used 3M 77. Easy to find and has very high tack. Spray both surfaces, let dry a few minutes until the glue is tacky, then stick together. You might have to keep applying pressure for a few minutes to a few places that separate but it will eventually hold.
Sabre 38 "Victoria"
Sabreman is offline
post #34 of 36 Old 05-21-2012
nickel25788's Avatar
I ordered a king size matress and cut it to fit vbirth. 4inch high density on bottom with a 2 inch med density with a 1 inch memory foam on top. Under neath it I put square deck grates the ones used on the cockpit floor that snap together. This keeps moisture from the foam. This setup works great for me.
nickel25788 is offline
post #35 of 36 Old 05-22-2012
Memory Foam Source
check out overstock dot com for their memory foam mattress toppers ... (I've got no affiliation with the company). I got one of their 4" foam toppers and really like it.
RonRelyea is offline
post #36 of 36 Old 06-11-2012
Re: Memory Foam Source
This may be the greatest upgrade to boating since the sail ! Thanks.
We bought a 4" memory foam topper from these guys for $180. We cut it to fit with a serrated knife and put a regular mattress pad over it to hold it to the current mattress.
For over 30 years, i've slept on everything from a cloth pipe berth to the cockpit. Our beds had what turns out to be 1.5 inch toppers on them before, which felt nice, but didn't really do much. Our mattresses themselves are in good shape, but like most, are very hard.
This thick topper was night and day. It's softer than the real temperpedic at home, but put over the existing mattress, we are brand new for what it would have cost just to have a good mattress measured.
Jeanneau 54DS
Replacing foam on couches and V berth MarkSF Gear & Maintenance 5 09-09-2011 07:40 PM
Replacing V-berth wall panels P36-2 hoppy Pearson 3 02-15-2011 07:57 PM
drycleaning foam? marcusn Gear & Maintenance 7 03-06-2008 11:27 AM
replacing foam in berth cushions wumhenry Gear & Maintenance 14 09-13-2007 10:55 AM
FORWARD HATCH-REPLACING WITH CLEAR TINT MATERIAL naturechick23 General Discussion (sailing related) 6 08-16-2004 10:08 AM
