Roller furling challenge - SailNet Community
post #1 of 6 Old 05-03-2012 Thread Starter
My challenge:
Boat: o'Day 27
Harken roller furling
When viewed looking down at the deck, I can turn the whole system easily by hand counter clockwise. However, I cannot turn it as easily clockwise. It seems to bind momentarily. What can I do?
Thank you in advance.
Iamrandywhite is offline
post #2 of 6 Old 05-03-2012
Re: Roller furling challenge
I assume your rigging isn't the issue, you should notice that. You may need to disassemble the bearings, clean them out (mineral spirits works well) and lightly grease them. What furler do you have?
Jeanneau 54DS
Minnewaska is offline
post #3 of 6 Old 05-03-2012 Thread Starter
I have a harken. I forgot to mention that this issue is without the jib attached. I did have a similar problem last year. How can I tell when I have the aft stay too taught? I don't want to makea small problem bigger byovertightening.
post #4 of 6 Old 05-03-2012
That's a little complicated. However, you can mark where it is now with tape on the turnbuckle, loosen it and see if it fixes your problem. If so, you might want a good rigger to tune you up. If not and you've been happy with sail performance, put it back where you found it and you're back to cleaning the bearings, check for corrosion, etc.
Jeanneau 54DS
post #5 of 6 Old 05-03-2012
RichH's Avatar
Several things can cause such binding:
1. Jib halyard too tight ... causes overloading and binding of the swivel bearings. Use a sail track lube on the groove of the foil so you dont need 'gorilla force' to raise the sail in its foil groove.
2. If the 'lead angle' of halyard—to—top swivel is less than the 'furlers specified halyard LEAD angle', the halyard will 'toggle' around the swivel and will cause such 'binding'. This 'toggling effect' is enhanced if the luff of the jib is MUCH shorter than the foil length; if so, a 'pendant' must be added to (usually) the head of the jib to make the connection to the top swivel .... so that the top swivel is 'almost' at the VERY TOP of the foil. If a pendant doesnt solve the toggling problem then a 'diverter block' should be added to the top of the mast to 'increase' the halyard—to—swivel angle.
If there is a 'large open space' on the furler foil between the top/head of the sail and the very top of the foil (jib too 'short' for the foil) this is lead angle problem is a possible likely cause of a binding furler. A 'pendent' added to get the 'top swivel' to near the top of the foil is the 99% correction.
3. shot or dirty furler swivel roller balls .... they dont last forever.
RichH is offline
post #6 of 6 Old 05-03-2012
It is possible that you've had halyard wrap sometime in the past and your headstay is damaged at the top. The wire might be birdcaged or have broken strands.
You should really go to the top and inspect the upper end of the wire at the terminal before proceeding.
knothead is offline
7.3 roller furling NomadPa S2 2 02-02-2007 02:55 PM
roller furling help kananumpua Learning to Sail 14 01-18-2006 05:33 AM
roller furling k8qer Gear & Maintenance 0 01-27-2002 09:27 AM
Roller Furling Dan_T Gear & Maintenance 6 11-02-2001 12:14 PM
Roller furling evecircleM General Discussion (sailing related) 5 10-08-2001 05:54 PM
