Help...Relocating stands - Page 2 - SailNet Community
 2Likes
post #11 of 18 Old 05-03-2012
ASA and PSIA Instructor
Re: Help...Relocating stands
You are asking questions about a process that could hurt you or others if you screw it up.
Having done this myself, once, my advice is to pay the yard to re-block the boat when you are ready...that will also allow you to get under the keel where the current blocks are...
sailingfool is offline
post #12 of 18 Old 05-03-2012
HANUMAN
RobGallagher's Avatar
Adding another set of stands is the best plan of attack.
If another set is not available:
Before moving a stand, first loosen the chain connecting the two stand by just enough links to move it, then re-attach the chain BEFORE sliding the stand over.
Never move more than one stand at a time, alternating sides.
This will STOP the boat from FALLING.
AGAIN, do not move a stand if the chain is NOT ATTACHED.
**Darwin award nominees for the spring of 2012 please disregard.
RobGallagher is offline
post #13 of 18 Old 05-03-2012
I've been aboard boats on the hard that had improperly placed or perhaps too few stands where doors wouldn't open they were so twisted. Of course, the majority of the weight is on the keel, but depending on the boat, stand placement matters.
Like I said, you could be fine for a short period of time with little stress.
Jeanneau 54DS
Minnewaska is offline
post #14 of 18 Old 05-03-2012 Thread Starter
patrscoe's Avatar
Long and short of it, we sold our previous sailboat and purchased this one late last fall and was unable to sail her to our marina so I put her on the hard there and decided to get the bottom completed and other misc work since our sail would be about 100 miles. The yard is small and I am finding out quickly, very limited. They were going to complete the bottom work but after months of no work being performed, I decided to take it on myself. I ask for other services (minor work), he agrees but nothing gets done so I can't really rely on them for much of anything. Unfortunate because I am really busy with work and family activities. Just want to get this work done, splash and move on to our marina.
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #15 of 18 Old 05-03-2012
Originally Posted by patrscoe View Post
....I ask for other services (minor work), he agrees but nothing gets done so I can't really rely on them for much of anything......
Whether competent or not, this has been my experience in 100% of the marinas I've ever dealt with. I realize they are in a somewhat weather dependent business and that messes with scheduling. However, simply forgetting or insisting on using a single vendor that is overbooked or always greasing the squeaky wheels is usually the problem.
I drop my yard manager (who I actually like quite a bit) an email every couple of days to follow up on what was committed by then. The pattern is 100% tested...... if I hear back from him immediately, they did the work. If I don't, they haven't. I sent a note yesterday morning that has gone unaddressed since. Work was scheduled for Tuesday, so I sent a note on Wed. Not looking good.
Jeanneau 54DS
post #16 of 18 Old 05-03-2012
Barquito
Barquito's Avatar
Maybe if they don't have the right people, the yard would be willing to let you hire outside help? Maybe even experienced SN'ers from the area?
Valiant 32
Barquito is offline
post #17 of 18 Old 05-03-2012 Thread Starter
patrscoe's Avatar
Kind of what I did. I hired a person I know that is currently out of work and has good knowledge of construction and sailboats. He is doing all the fun work like sanding and sanding and sanding....
Yes, that is what the Boat Yard owner kept on saying, weather is delaying the start of the work for the last three months but I don't necessarily agree with him. Anyways, I felt like I am bashing them online and I don't want to do that, not really fair and respectable. Perhaps he sees me as a out-of-towner and knows I will be gone soon.
Thanks for all your help!
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #18 of 18 Old 05-03-2012
tommays's Avatar
Around here 7 is the normal amount for 30' boat
The 7th bow stand is how the movers get under the boat to pick it up and while it use to make me pretty nervous IF the keel is well blocked the stands are just balancing the boat and there should be no significant load on any single stand
Go at it slow and if the boat is et up right you should be able to lower one stand at a time without and movement IF this is NOT the case STOP
I ALWAYS leave the chains between a set of stands when i am moving them just in case and never move the stand more than a tiny bit away from the hull
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Please help - Relocating to Edenton, NC connellyjc General Discussion (sailing related) 2 02-11-2012 11:28 AM
Relocating Water Heater JiffyLube Gear & Maintenance 5 04-15-2011 08:49 AM
Thinking of relocating nursinadream Introduce Yourself 2 10-15-2010 11:17 AM
Relocating Icebox Bermuda30 General Discussion (sailing related) 5 11-18-2007 06:57 PM
Relocating via ICW limey Living Aboard 1 08-29-2004 11:54 PM
