Leaking transducer through hulls - SailNet Community
 3Likes
post #1 of 15 Old 05-03-2012 Thread Starter
rhsanborn's Avatar
The speed and depth sensors leak for a few weeks at the beginning of the season until the fiberglass swells and it stops up. It wasn't something I noticed when we bought the boat as it was in the water, but the PO had wrapped paper towel around the sensors to sop some of this up until it self sealed. This doesn't seem right. So, two questions.
1) Is it REALLY terrible for the glass around those ... i.e. how much water penetration. If it's really bad, then I absolutely need to deal with it before I put it in the water, but...
2) Is the fix easily undoable. I want to replace my instruments in the next year or two, but hadn't budgeted for it this year. I'd hate to use 5200 to seal it up or something and then have no chance of getting them out next year.
1978 Morgan OI 30
Au Gres, MI
Lake Huron
rhsanborn is offline
post #2 of 15 Old 05-03-2012
celenoglu's Avatar
Re: Leaking transducer through hulls
Fiberglass absorbs maximum 3-3.5% water. But this might cause osmosis. It is best to apply a few coats of epoxy to the holes. Tightening the thru hulls after this operation should stop water ingress. you can use 5200 (poliurethane) before attaching the the thru hulls. Polysulfide is less stickier than poliurethane.
celenoglu is offline
post #3 of 15 Old 05-03-2012
Irrationally Exuberant
Are you sure there isn't some wood involved? It definitely swells. I only ask because this was the case with our transducer that leaked for a couple of days after splash. As I remember it, I found a square of (rotting) plywood bonded to the inner hull, and the transducer clamped to the plywood. I removed the plywood and 5200'ed a piece of fiberglas sheet (from McMaster-Carr) in its place for the fix.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #4 of 15 Old 05-03-2012 Thread Starter
rhsanborn's Avatar
I guess I'll find out this weekend. I'm heading out to remove shrink wrap and start on a list of projects. I think this is more of a scouting mission than anything
1978 Morgan OI 30
Au Gres, MI
Lake Huron
post #5 of 15 Old 05-03-2012
Señor Member
PorFin's Avatar
Pull the 'ducers and rebed them properly before you splash -- the peace of mind alone will far exceed the work involved.
Pay close attention to any backer blocks you remove as you disassemble. Depending on your hull shape, your depth 'ducer should be on a beveled block that orients it vertically and not necessarily perpendicular to the hull. If the blocks are made out of plywood -- and many are -- make sure that they are sealed; if they aren't, inspect them very carefully for any indications of delamination or rot. If they show any signs of damage, make new ones and seal them with a couple of coats of epoxy.
I'd be very hesitant using 5200 for anything here -- it's just too permanent.
Faster and mitiempo like this.
PorFin is offline
post #6 of 15 Old 05-03-2012 Thread Starter
rhsanborn's Avatar
Thanks guys. I'll take a look for the backing block. I suspect you may be right that it needs to be replaced and the transducer rebedded. I strongly suspect I won't be eager to replace anything for a few more years, just as well, maybe instruments will come down in price a bit more :P
1978 Morgan OI 30
Au Gres, MI
Lake Huron
post #7 of 15 Old 05-03-2012
Señor Member
PorFin's Avatar
This shouldn't cost you much at all (other than time that is.)
Plywood backing blocks are perfectly acceptable (as long as they're sealed) and you can make these yourself. Drilling the hole for the depth 'ducer to the proper angle would be a snap on a drill press, but can also be done freehand as long as you're careful. Your tolerances are not critical (i.e., a gap of 1/16 should be fine), since the sealant will fill that gap easily.
So, you're looking at time invested, a tube of sealant, some scrap plywood and a little epoxy -- should come in at under $25... Waiting and being forced to haul the boat once your current leak becomes unmanageable? Hundreds... Pretty clear math for me
PorFin is offline
post #8 of 15 Old 05-03-2012 Thread Starter
rhsanborn's Avatar
Pretty clear math indeed. I'll be rebedding and rewiring all the instruments though. I just don't want to do it again for a while. Definitely worth doing. I'm slowly undoing some of the silly work arounds from the PO... one at a time.
1978 Morgan OI 30
Au Gres, MI
Lake Huron
post #9 of 15 Old 05-03-2012 Thread Starter
rhsanborn's Avatar
This is nothing, ball valve seacocks, that probably need to be rebedded as well, and then the sanity system ... yuck.
1978 Morgan OI 30
Au Gres, MI
Lake Huron
post #10 of 15 Old 05-03-2012
Señor Member
PorFin's Avatar
And that, my friend, is the true definition of boat ownership.
dnf777 likes this.
PorFin is offline
Thru-hulls ctj1950 General Discussion (sailing related) 8 04-04-2011 12:39 PM
16' hulls jackie19 Gear & Maintenance 0 06-24-2010 01:26 PM
GRP hulls radly53 Boat Review and Purchase Forum 4 03-20-2007 04:35 PM
Through hulls drynoc Gear & Maintenance 5 08-14-2006 01:47 PM
thru hulls dbg Gear & Maintenance 3 10-21-2002 06:47 AM
