Old 05-06-2012
Iamrandywhite is on a distinguished road
Fixing a slow water leak
I have an O'Day 27 with a small leak at a through hull fitting. As the boat is in th water ( I guess I didn't look closely enough when putting in), is there any sealant I can use with the fitting leaking without pulling the boat?
Thank you in advance
  #2
Old 05-06-2012
Mobnets's Avatar
Mobnets is on a distinguished road
Re: Fixing a slow water leak
Is it a leak at the thru hull fitting or a seacock assembly attached to the thru hull fitting?
Mobnets
1973 Paceship Chance 32/28 "Westwind"
  #3
Old 05-06-2012
The leak is not coming from where the housing contacts the hull. Instead, it is coming through between two parts of the transducer. Unable to tighten these pieces any more for fear of breakage. Would much prefer some sort of sealant.
  #4
Old 05-06-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Butyl tape rolled into thin pieces?
Everybody has one:
  #5
Old 05-07-2012
mitiempo's Avatar
Undo the 2 pieces and use a sealant that will not harm the plastic, then re-assemble. Butyl could be used or Sika Flex.
Brian
  #6
Old 05-07-2012
Problem solved. I was able to stop the leak long enough to seal it with silicon caulk. Watched it for several hours and is ok. Will check periodically also. Thank you for your assistance.
  #7
Old 05-07-2012
CorvetteGuy's Avatar
72 C&C Corvette
CorvetteGuy is on a distinguished road
I fixed a seacock with two part epoxy putty, it cures with the presents of water. $15 at the local boat shop, or canadian tire. held for a season till I could replace it but sure it would have lasted longer.
  #8
Old 05-08-2012
DivingOtter's Avatar
Otter
DivingOtter is on a distinguished road
splash zone or wet dry brand underwater epoxies
You may post attachments
You may edit your posts
Slow, slow, slow and menu not responding cupper3 SailNet FAQ's 35 05-05-2012 06:30 AM
slow leak in Merit 25 zephyrhas Gear & Maintenance 3 03-11-2010 09:13 PM
water tank leak grinfax Gear & Maintenance 2 10-15-2008 05:33 AM
'31 Citation Water Leak bruce804 Irwin 5 03-07-2008 02:36 PM
At sea. Aviva Challenge: Dee Caffari close to fixing water maker @ BYM Sailing News NewsReader News Feeds 0 04-12-2006 01:15 PM
SEO by vBSEO 3.6.1
