Our marina has individual
pump out hookups at the slips which is a nice touch. I successfully pumped-out our
holding tank about 2 months ago, everything went according to plan.
I attempted a second
pump out about 3 weeks ago: primed the
pump properly, it had suction, then once sticking the nozzle in the deck fitting, nothing was pumped out; the only thing going on was the sound of air entering the intake vent. My assumption was that the person we have clean our boat every couple of months had pumped it out without telling us (which was fine by me!) since everything was behaving as if the tank was empty.
Tried to
pump out again this weekend in order to put some cleaning solution in the tank - same problem. Only air is being pulled into the intake vent and we know the tank isn't empty. Pretty sure there aren't valves on board to switch before pumping out - so it should definitely work.
Any ideas on what to check or what could be the cause? There's no 'head odor' so no obvious leaks. Thanks in advance...
