Mercury 8.0 HP 4 stroke outboard won't lock down. - SailNet Community
post #1 of 6 Old 05-09-2012 Thread Starter
shadowraiths's Avatar
Had planned to practice docking today but was unable to get the motor to lock in the down position. Which means it would basically "pop up" out of the water when going in reverse. I was able to lock it before but it would not lock today. Am thinking part of the problem is that since the motor is really too big for the transom hole its mounted in, I have to manually push the bar to let the motor down. So, perhaps its getting stuck in that position? Any advice would be appreciated!
shadowraiths is offline
post #2 of 6 Old 05-10-2012
Re: Mercury 8.0 HP 4 stroke outboard won't lock down.
You might try taking the motor off and see if it locks? Sounds like it might be binding in the mount?
Paul T
dabnis is offline
post #3 of 6 Old 05-10-2012
bljones's Avatar
pictures would help.
It's 5 o'clock somewhere:
bljones is offline
post #4 of 6 Old 05-10-2012
tommays's Avatar
Normally there is a linkage that locks when you engage reverse BUT it does not take much dirt or rust to hang it up
Cleaning and lubing what ever is there so it moves correctly should solve the issue
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #5 of 6 Old 05-10-2012 Thread Starter
Thanks all for your feedback. Turns out it wasn't an issue after all The guy who was going to teach me how to dock was unfamiliar with outboards. Did a quick test and it locks fine, in reverse, and is free in forward. Which, from what I am reading, is how it is supposed to work.
post #6 of 6 Old 05-13-2012
tap
On my Tohastu 8HP, which is the same as Mercury 8 HP depending on year, it will lock in reverse and also can lock in neutral. Locking is neutral is controlled by which hole is used for the linkage between the clamp that locks it down and the thing that gets pushed by the shift rod. It doesn't lock in forward. In fact you have to shift to forward (or neutral if you have it unlock in neutral too) to tilt the engine back to get it out of the water.
tap is offline
Thoughts on the Mercury 4 stroke 9.9 hp outboard? SayGudday Atomic 4 9 03-02-2013 02:14 AM
Problem changing gear lube on Mercury 3.3hp 2-stroke bacoms Gear & Maintenance 16 06-16-2009 01:20 PM
mercury 3.3 2 stroke running problems honsail Gear & Maintenance 2 06-16-2009 08:26 AM
Mercury 2 Stroke Misfiring? dirtchickn Gear & Maintenance 0 01-16-2005 10:48 AM
Mercury 25 4-stroke dlschilke24 Gear & Maintenance 0 05-25-2004 07:31 AM
