Leaking Thru Hull - SailNet Community
 1Likes
  • 1 Post By obanarama
post #1 of 9 Old 05-12-2012 Thread Starter
Leaking Thru Hull
Hello everyone!
My partners and I recently bought a 1978 Catalina 30 which we have been fixing up for the last month. Hopefully today we put the final touches on her (for now), and go sailing!
One thing has been bugging me though. The PO had new thruhulls installed just a few months ago, but they seem to weep water. I've attached a picture so you can see what it looks like. It's not a lot of water at all, just enough to keep that area constantly wet. It looks to me like its coming from the junction of the thruhull and the valve
I was wondering if i can just crank down on that valve a bit and hopefully stop the weep.....or even if i could crank on the nut that holds the thru-hull in. or if either of those is just a bad idea.
thoughts?
thanks!!
greg
sfbaysailing is offline
post #2 of 9 Old 05-12-2012
mitiempo's Avatar
Re: Leaking Thru Hull
Greg
With that kind of installation you have to be careful that you don't break the seal between the through hull and the hull itself. With a proper install that is not a problem as there are 3 bolts used.
Also there is a likely thread mis-match between the valve and the through hull which means there are only a few threads engaged.
They also look a lot older than a few months.
Here are a few good links explaining through hulls and their installation.
http://www.pbase.com/mainecruising/seacock_primer
http://www.pbase.com/mainecruising/replacing_thruhulls
Brian
mitiempo is offline
post #3 of 9 Old 05-13-2012
I think that your leakage is due to the thread mismatch that Mietiempo refers to. At the very least, to stop the leak, you should remove the valve and re-apply teflon tape to the thread (for which it would have to come out of the water)
It's hard to say what the problem is from the blurry pic. But I strongly suspect that you have a thread mismatch, and I also suspect that some of those tail fittings are not marine bronze, hence the visible corrosion.
MarkSF is offline
post #4 of 9 Old 05-13-2012
72 C&C Corvette
CorvetteGuy's Avatar
worst comes to worse grab some 2 part aquamend marine epoxy putty, I was forced to use some with a leaky through hull years ago it made it through a season untill the boat got hauled again. If you can pull the boat change the seacock and do it right if not putty it up.
CorvetteGuy is offline
post #5 of 9 Old 05-14-2012
Irrationally Exuberant
Thru hulls shouldn't leak. Something was done wrong--the thread mismatch sounds likely. I wouldn't try to tighten them, for the reason mitiempo points out. I think you are facing some re-doing there with the boat out of the water.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #6 of 9 Old 05-14-2012
celenoglu's Avatar
The boat should beon land. Use Loctite to seal. Teflon is good the valve might turn on the thruhull which might cause leakage.
celenoglu is offline
post #7 of 9 Old 05-14-2012
Greg,
I can't help with the thru-hull leak, but do say "Wassup!!!" to Damon C for me. And get that boat sailing already!
~ Oban
dcianci179 likes this.
obanarama is offline
post #8 of 9 Old 05-14-2012
Sabreman's Avatar
Hoses should have 2 clamps as well.
Sabre 38 "Victoria"
Sabreman is offline
post #9 of 9 Old 05-15-2012
Originally Posted by obanarama View Post
Greg,
~ Oban
oban, how the hell did you know greg was my partner? That's freaky dude...
D
dcianci179 is offline
Leaking hull/keel joint laHolland Gear & Maintenance 14 07-04-2010 07:06 PM
leaking plumbing through hull fitting idealflaw Gear & Maintenance 14 07-26-2008 07:19 AM
leaking aluminum hull lbdavis Gear & Maintenance 6 07-25-2008 06:07 PM
Leaking hull deck joint sailnaway Gear & Maintenance 0 10-12-2004 07:53 AM
Leaking Hull skimorey Gear & Maintenance 2 04-13-2003 05:06 AM
