stuffing box stern tube different dia's??? - Page 2 - SailNet Community
post #11 of 14 Old 05-15-2012
Re: DON'T do it!!
Originally Posted by Chris12345 View Post
Well, I call your raised double strong disagreement, but we will likely have to wait a decade or two to see.
Mind you, somehow mangling an ill-fitting hose over two fittings of different size was likely the original condition of the boat, in which it was insured when brand new. It will be hard to beat THAT in order to make the stuffing box a liability.
And I see absolutely no reason why solid-against-soft should slip less than soft-against-soft.
I'l have to agree with the don't do it. Yes you can make anything work with a big enough hammer, but if the packing box slips off you will sink the boat. There is no need here to introduce another layer that might leak, or slip. If it was neccessary, IE the right packing box was no longer made, or you are in the middle of the ocean, it might be different.
$80.00 is not even 1 boat buck, cheap to do it right.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #12 of 14 Old 05-15-2012 Thread Starter
johnnyandjebus's Avatar
Re: stuffing box stern tube different dia's???
OP here, an update;
If at all possible I woulds prefer to buy the correct replacement. I took a look at the supplier listed in the first page of this thread, sadly to ship to Canada they require a money(wire) order. Seriously? I could start a rant on USA based companies who make it difficult to ship to Canada
Via google I found another company that sells what I am looking for and am waiting to here back from them.
Originally Posted by hellosailor View Post
John, since you have a lathe, why not build up 3-4mms of a good filled epoxy on the tube, then turn it down to 1-3/4" so the two match? Epoxy is a structural material, after all. Easier than turing Delrin blocks and fussing with all that.
Or, of course, just buying the new one in the right size.
hellosailor
Your last sentence says it all, for <> 100 $ I prefer to buy rather than make. My lathe turning skills are limited, with that said if I need to I will use it for this situation, as you discribe.
I suspect I could just buy 1 3/4 hose, clamp it all down and be done with it. It worked for the first 30 years....
With that said the boat is out for the season so why not take the time to do it right and the forget about it for the next couple of decades?
Thanks for all of the feedback,
John
"The more I know about people, the better I like my dog."
-- Mark Twain
"If you canít explain it to a six year old, you donít understand it yourself.Ē
--Albert Einstein
johnnyandjebus is offline
post #13 of 14 Old 05-16-2012
tommays's Avatar
While we are all adults and can do what ever we want
The correct stuffing box hose is REALLY stiff stuff and its gonna be on there another 20 years so it is not a corner cutting place IMHP
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #14 of 14 Old 05-16-2012
mitiempo's Avatar
And it will be next to impossible to stretch it.
Brian
mitiempo is offline
Mismatch between stern tube OD and prop shaft/standard stuffing box size jameswilson29 Gear & Maintenance 20 12-27-2011 08:17 AM
Taswell cc 43 stern tube O.D. Lotus43 General Discussion (sailing related) 0 07-18-2008 08:00 PM
Recommended hose for stern tube to stuffing box GBurton Gear & Maintenance 10 03-18-2008 09:50 PM
Stern Tube Repairs, B29.9 hshannon Bristol 1 07-13-2006 02:08 PM
The Stuffing Box and Stern Tube Tom Wood Gear and Maintenance Articles 0 04-27-1999 08:00 PM
