Anchor Rode and Scope for Marker Buoy - SailNet Community
post #1 of 4 Old 05-13-2012 Thread Starter
Hey all,
Does anyone know what the recomended scope is for the rode on a smaller PVC marker bouy?
Thanks
76 C&C 38
jetdrvr393 is offline
post #2 of 4 Old 05-13-2012
blt2ski's Avatar
Re: Anchor Rode and Scope for Marker Buoy
When I have install anchor buoy chains etc in the past, usually about 1.5-1 ratio. This should be enough to cover the highest tide if any water, along with added wave height, and a minimum safe factor to the buoy is not pulling the anchor system up and moving it.
As reality is, you do not want an anchor buoy, or marker buoy to move much, where as a normal 5 or 7-1 ratio as used for boat anchoring, will make the anchored item move in a pretty big arc! You also want to rely on a bit more weight than one might when anchoring a boat with a larger ratio of rode etc too.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #3 of 4 Old 05-13-2012
celenoglu's Avatar
The scope will depend to the type of anchor. If you use weight or 2 or three anchors equally angelled and a rode from the center you will not need any scope except for tides and waves. Otherwise use the scope you use when anchoring.
celenoglu is offline
post #4 of 4 Old 05-13-2012
overbored's Avatar
it is best to add some chain on the bouy end if not using all chain. this helps keep the bouy it self lighter and the chain keeps the bouy more upright in high winds. the chain also help keep the bouy line from getting caught on someones keel or rudder. with the chain between the bouy and the rode you can have more scope if needed.
"GOLD RUSH" PRINDLE 16
overbored is offline
Anchor retrieval buoy sailak General Discussion (sailing related) 7 07-02-2009 04:27 PM
Splicing anchor rode MtHopeBay Seamanship & Navigation 42 04-17-2009 06:37 PM
Anchor rode question josrulz Gear & Maintenance 14 01-12-2009 02:02 PM
Markers for Anchor Rode Neicy Gear & Maintenance 19 07-08-2008 09:28 PM
anchor rode maestro Gear & Maintenance 9 06-19-2005 11:38 AM
