Identifying a Yanmar - SailNet Community
post #1 of 12 Old 05-15-2012 Thread Starter
I have a three cylinder Yanmar diesel which has the fresh water intake to cool the internal cooling circuit. Is there a way to precisely identify which Yanmar it is, e.g. 3GM30, 3GMD, 3GM30F, through the engine serial number? The engine is in a 1985 Cal 33 is almost certainly original to the boat.
TIA for any help/suggestions.
RichardM
S/V Raven
Cal 33
RichardM is offline
post #2 of 12 Old 05-15-2012
DrB
Re: Identifying a Yanmar
If it is a fresh water cooled motor (ie has anti-freeze in the heat exchanger), that it is most likely a 3GM30F. The F means Fresh Water cooled. A 3GM30 is raw water cooled. I haven't heard of a 3GMD, but that doesn't mean it couldn't be that.
I have a 3GM30F motor in my boat. If you are looking at the pulley's, the oil filter is to the right, the sea water impeller is to the lower left, behind the lowest pulley and the air intake is on the right side, top, about half down the length.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #3 of 12 Old 05-15-2012
You could also have a 3GM30 that was converted to fresh water. Do you have a Yanmar Service manual?
aa3jy is offline
post #4 of 12 Old 05-15-2012 Thread Starter
Yes, I have a manual, but am not sure its what came with the engine/boat. Its at the boat, so I can't check specifics right now.
The fresh water impeller is off to the left as you are looking at the front of the engine, if that's any help.
RichardM is offline
post #5 of 12 Old 05-15-2012
casey1999's Avatar
RichardM
S/V Raven
Cal 33
There should be a name plate on the engine (in the area where the belts are), might need to wipe the area with rag to find it. The name plate should state model and serial number. There should be a name plate also on the transmission (oposite side from where belts are). 3GMD is a direct sea water cooled 3 cylinder Yanmar. Check the pic, name plate is hard to see but is the green/silver rectangle between the belts, just above the place where a hand crank would go.
casey1999 is offline
post #6 of 12 Old 05-16-2012
Ilenart's Avatar
I use to have a Yanmar 2QM20H and the name plate was in a difficult place to see on the left hand side of the engine (facing forward) hard up against the bulkhead. The only way I could see it was to to take a photgraph of it with a small camera with a flash as there was only a couple of inches space. The serial number was enscribed on the engine just to the left of the name plate.
Ilenart
Ilenart is offline
post #7 of 12 Old 05-16-2012
JimsCAL's Avatar
My 1985 Cal 33-2 has a 3GM30F so I'm pretty sure that's what you have. A Yanmar dealer should be able to confirm that from the nameplate data.
JimsCAL is offline
post #8 of 12 Old 05-16-2012 Thread Starter
Thanks for the information. I'll go up tomorrow and get the information off the engine and check with a dealer.
Nice to hear from another Cal 33 owner.
RichardM is offline
post #9 of 12 Old 05-16-2012
The designation on my 3GM30 name plate is: 3GM30 93.
Engine was installed in 98. Yard mechanic told me that the 93 designated the year when the engine was built. Some on these forums advised that the engine was converted to fresh water which is why there is no "F" on the end of the number.
Turns out all wrong. Another mechanic told me that it was definitely not converted. After speaking with Mack Boring I learned that some individual boat builders had their own model designation put on the engine. In my case, the "F" was deleted from the model number and the "93" was specific to a boat builder. The engine never made it to the builder - probably due to an order cancellation.
I never took the serial number any further to learn who originally ordered the engine or what year it was built.
Mike
OasisII is offline
post #10 of 12 Old 02-28-2016
I am looking at a prospective purchase of a a boat that has been re-engined with a 3GM30F. The serial number is 10531 from the plate on the front of the engine.
Is there any way to ascertain the year of manufacture of this engine from the serial number??
I do know that THAT ENGINE WAS ONLY PRODUCED FROM 1983 to 2005.
Due to changes in ownership, I am unable to find out what year the 3GMF engine was installed to replace the 2GM that was the standard manufacturers install in 1979. The boat is a 1979.
Maybe someone with a known year of 3GM30F with a serial number similar to this one could give us a clue.
The hour meter would have helped ascertain the engine condition/age but the stock engine was removed at 1222 hours. That hour meter remains with that number showing. A new hour meter was installed at some point, right next to the old one, but never hooked up.......ir still reads ZERO?!?! Go figure!
Since the average sailboat user runs about 200 hours per year, that would point to the engine being replaced about 6 years from 1979, or 1985, by dividing the 1222 by 200. That's as far as we can guess, so far.
Thanks for helping,
Pete
mustangxr is offline
Need help identifying svsundancer Gear & Maintenance 2 01-28-2012 10:15 AM
Help identifying a boat Armchairsailor2 General Discussion (sailing related) 9 08-17-2011 11:05 AM
Identifying this 27'er bashmaki Boat Reviews 12 11-23-2009 04:33 PM
Need help identifying an engine tojaso Gear & Maintenance 4 05-25-2009 11:58 AM
Help Identifying a Sailboat? dellengwyn Boat Review and Purchase Forum 6 09-10-2008 11:20 PM
