Charley Noble, tankless water heater vent - SailNet Community
post #1 of 17 Old 05-15-2012 Thread Starter
Canuck Sailor
Send a message via Skype™ to canucksailorguy
Hello all - I'm about to install a tankless water heater (on demand LPG), vented through the cabin roof. Any ideas on where to find a Charley Noble (none on ebay!), or will I have to design and make one? Also, what pvc or plastic type materials will work here, or am I stuck with stainless?
Thanks, look forward to a helping of the wisdom here.
Wally
s/v Gypsy Wind
lying Annapolis, MD
canucksailorguy is offline
post #2 of 17 Old 05-15-2012
Re: Charley Noble, tankless water heater vent
Wally,
Consult your installation/owners manual for type of material the vent piping & termination
kit/assembly needs to be. Being up in Canada the material may be a different standard than what would be used in the lower 48 so be careful where the advice comes from. You guys are on the CGA standard.
Bob
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #3 of 17 Old 05-15-2012 Thread Starter
Canuck Sailor
Good thoughts - although I'm here in the US now, and there are no 'approved' standards for a boat install. Couple of thoughts - the company says a standard flexible dryer pipe works, then I was thinking a cap such as Home Depot sells (3 in. Vertical Cap-3080 at The Home Depot).
Comments anyone?
post #4 of 17 Old 05-15-2012
One of None
deniseO30's Avatar
what make and type of tankless you using? power vented? most if not all vent terminations will let water in and down the pipe not good for most tankless units.
My last project!
deniseO30 is offline
post #5 of 17 Old 05-15-2012 Thread Starter
Canuck Sailor
I'm seeing this will be a problem. The unit is an EZ Tankless 101 - it's a flue type. I think I may have to have a cap for when it's in use, and a way to seal the pipe off when it's not in use and/or I'm underway. Not insuperable, but not as easy as I'd first thought.
post #6 of 17 Old 05-15-2012
One of None
deniseO30's Avatar
I'd suggest you use the pipe listed on their site. Most types of natural draft gas units need a tee to vent to first. That way water won't enter the unit but will drop down in the tee. You won't be able to use pvc to vent it. the exhaust temp will be too high because the ez 101 is NOT a condensing type gas unit it's afue rating would be low. Also there are no afue ratings on the site.
I don't like this statement in the "green" section of the site.
EZ Tankless on demand water heaters are very competitively priced. When bringing our products to market we knew that we had a green product, but knew that most people would not be prepared to purchase an environmentally and energy efficient product if it was several times more expensive than the existing technology. We knew that the cost of a replacement storage tank water heater is generally between $400 and $700. Part of our business plan was to bring to market a product which sold at around these prices. Naturally we did not want a product built to a price point, so we built the highest quality product we could, using the highest quality materials, and did other things to keep our prices low.(i.e. refusal of Energy Star Label, No Dealers, etc…)
My last project!
post #7 of 17 Old 05-15-2012 Thread Starter
Canuck Sailor
I was thinking of using that pipe (or suitable sized flexible stainless pipe) to the hole where the vent would exit to the outside, and the cap over that. Set up the pipe so that it can be put to the side when the unit is not in use (when not showering, dishwashing) and have a cap that will prevent water from coming in.
The factory told me it was possible to use the same type of flexible plastic 'hose' used for dryers. Apparently, there's not a lot of heat here. That may be the easiest solution. I may fire the unit up and see just how much heat actually is produced before installing.
Not sure what it is in that green statement you don't like. Seems like a business plan that is geared towards providing a low cost but high quality product. As noted, things like Energy Star or a dealer network cost money.
post #8 of 17 Old 05-15-2012
One of None
deniseO30's Avatar
natural draft is about 70 -80% afue. Natural draft is also way cheaper to manufacture. Energy star rates are over 90% afue and extract so much heat from the burned gas they need a condensation drain. but of course home owners are into the numbers. We installed (I'm in the business) a dual purpose on demand in my house in Dec. cut the hot water and heating costs by 60% from the oil fired boiler I had installed when I bought the house.
My last project!
post #9 of 17 Old 05-16-2012
mitiempo's Avatar
Use the same type of Charley Noble you would with a bulkhead mounted propane heater or a diesel fired heater. You can find marine quality stacks and deck fittings here DickinsonMarine.com - Propane Fireplaces
I can't see any type of plastic working - melting, but not working. I have owned tankless propane water heaters in the past and liked the convenience.
If you are surveyed for insurance they will probably ask for its removal as it doesn't meet ABYC standards. Insurance companies hate them. The standards call for a vent, no open pilot light, AND a closed combustion chamber. The only one I know of that can meet the standards is the Precision Temp but it is a lot more expensive.
Brian
mitiempo is offline
post #10 of 17 Old 05-16-2012 Thread Starter
Canuck Sailor
This is all great stuff, and thanks! Interestingly enough, the guy at the factory tells me I can use a clothes dryer vent and flex piping for this - I'm going to hook it up with a hose, outside, and see just what kind of heat comes out the flue.
Denise, what is afue? You keep mentioning it.
Brian, thanks for the Dickinson Marine ref - also, Victoria Harbour - would that be the one in Ontario, in Georgian Bay?
Eemax "marine/rv" Tankless Water Heater - EX2412M and insuarnce? SanDiegoChip Gear & Maintenance 11 06-23-2016 10:51 PM
Need to replace dead Wolter tankless water heater Moxieskipper General Discussion (sailing related) 11 09-01-2013 01:04 PM
tankless water heater waterwks4me General Discussion (sailing related) 8 06-27-2011 06:43 PM
Tankless hot water heaters amayotte Gear & Maintenance 2 02-22-2008 11:33 AM
Tankless Water Heaters Pub911 Gear & Maintenance 14 01-21-2008 10:42 PM
