Strainer between pump and engine? - SailNet Community
post #1 of 4 Old 05-16-2012 Thread Starter
I'm have a closed cooling system with a heat exchanger and am considering a small Vetus strainer inline on the discharge side of the coolth pump (not the raw water pump), The idea would be to catch any fragments of a failed impeller before they get to the engine. Do any of you do this? Is there a superior solution?
Hudsonian is online now
post #2 of 4 Old 05-16-2012
celenoglu's Avatar
Re: Strainer between pump and engine?
Normally the cooling fluid of the engine is circulated with a centrifugal pump which does not have rubber parts.
celenoglu is offline
post #3 of 4 Old 05-16-2012
Senior Cruiser
sea_hunter's Avatar
Yeah, no.
sea_hunter is offline
post #4 of 4 Old 05-16-2012 Thread Starter
My Yanmar 2GM has rubber impellers in both the raw water pump and the pump that circulates the coolant through the engine. Having retrieved an errant impellor vane from the head I'd like to eliminate the potential for recurrence.
After I wrote my initial inquiry, I found that the Vetus strainer is only designed to operate to 55C; I'm unsure of the coolth temperature at that point in the system but it's probably less.
I also wrote the Jabsco help desk who responded, "We don't recommend installing filters in cooling discharge lines as they may cause a restriction in flow and create an additional point of potential failure in the system."
Sea water strainer for engine intake - flat jarcher Gear & Maintenance 11 07-08-2010 07:56 AM
Which way to face an engine strainer? brak Gear & Maintenance 19 07-25-2007 06:23 AM
Need water pump for Atomic 4 engine Diligence Ericson 2 05-16-2007 02:34 AM
Engine Flood Pump....Would this work ? MikeinLA Gear & Maintenance 1 09-08-2006 06:25 AM
boats with easy engine, seacock, sea strainer, etc access night_raver Boat Review and Purchase Forum 3 08-26-2004 11:11 AM
