bilge pump system with mulitple bukheads??? - Page 2 - SailNet Community
 2Likes
post #11 of 18 Old 05-16-2012
Seņor Member
PorFin's Avatar
Re: bilge pump system with mulitple bukheads???
Maybe it's just me, but the two phrases "keeping it simple" and "four watertight compartments" on a 42' boat appear to be diametrically opposed...
If you intend to maintain the integrity of each compartment, then you'll need to dedicate independent pump systems for each one.
I think you are overestimating the risk involved in powering all of your electric pumps from one battery location. As long as you are diligent in your selection of materials, how you route your runs and ensure you make good watertight connections you can eliminate most of that risk. Will it be totally safe from failure? Of course not. However, if you add a battery bank to each compartment then you'll be adding a bunch of weight, wiring, complexity, and maintenance and emptying your wallet.
I guess my bottom line is this: You seem to be over-engineering this one. My assumption is that the designer of the boat intended that she could remain afloat with one compartment flooded. If that happens, you are going to be calling for help. If you suffer a hull breach that compromises more than one of your compartments, you will be in deep doo-doo regardless of your bilge pump set up.
PorFin is offline
post #12 of 18 Old 05-17-2012 Thread Starter
lupussonic's Avatar
Thanks for your reply Porfin....I am where I am, at 42' and with bulkheads; no point taking them out!
Redundancy to me means that if one type of pump doesn't operate for whatever reason i can reach for another. Therefore, if redundancy is to be followed, and according to the advice previously given in this post (which i am greatful for), it would mean having three types of pumps in each compartment, a total of 12 pumps, which quite naturally would be rediculous, nay impossible.
You may have your wires crossed in thinking that i was advocating an electric pump and battery in each compartment. That is what i want to avoid through clever hosing.
What I want is one of each type of pump (electric, manual and engine driven) in the aft compartment, next to the batteries. While I am aboard I am able to operate taps and pumps so there is no problem. It is when the boat is left for a week or two unattended that gaps in the system arise.
Imagine just two compartments...
...they both have a strum box and hose that go to a third where they join in a manifold to an electric pump. One of the compartments leaks and triggers the float switch which starts the electric pump. A non-return valve in the dry compartment's hose will stop the water from the first from flowing down it and flooding the dry compartment.....BUT the pump will suck air in from the dry one aswell as water from the wet one, substantially reducing the pumps output.
The 'air suck' issue is the sticking point in an otherwise simple, minimal and sensible pump layout for when on the boat.
Do boats with watertight bulkheads all have three kinds of pump in each room, hermetically sealed from each the others? Or do they have one electric in each? Do they have two float switches in each compartment?
I cannot find anything on the net on this subject, despite days and days of searching. My only supposition is that they either have dozens of pumps and through hulls (which I want to avoid) or that they are vulnerable when left unattended.
Anyone out there with bulkheads? I'd love to know how your pumps are laid out!
lupussonic is offline
post #13 of 18 Old 05-17-2012
celenoglu's Avatar
Non return valves work very well when they are clean. Debris will keep them at least partially open. That is if one compartment has water in, and water is pumped, you can be sure that something will block the non return valve of that section. Next time there is water in a different bulkhead,the water will find its way to the first bulkhead.
celenoglu is online now
post #14 of 18 Old 05-21-2012 Thread Starter
lupussonic's Avatar
How about a valve that closes the bottom of the bilge pipe when it has no water? See attached diagram. It would ALL need to be housed in a mesh to act as a strainer, and need tinkering with to get the float right, so the pumps don't suck the valve onto it when active, but it could solve the problem of sucking air from a dry compartment when a wet one is being pumped...any thoughts?
post #15 of 18 Old 05-21-2012
As a passenger vessel I' m required two water tight bulkheads. Each bilge has it own electric pump with high up thruhulls and backflow stoppers, controlled from common panel. Each bilge has two sensors ,one for auto pump and other (separate circuit) for flood alarm.Each bilge is hard plumbed to engine driven Japsco thru ball valve manifold and valves at each bulkhead which are normally open.Everything is tested every year by CG so I know it works and couldn't be simpler.
Capt Len is online now
post #16 of 18 Old 05-22-2012 Thread Starter
lupussonic's Avatar
Thanks for that...is it mandatory for passenger carraige to have a dedicated pump for each compartment? When you have your engine Jabsco running does it suck air up from dry compartments? Or do you have to shut the valve first?
post #17 of 18 Old 05-22-2012
It sounds like you have 1 very large pump, and wish to have 4 pipes, 1 sucking from each compartment?
Usually in smaller boats you have a smaller pusher type submersable pump in each compartment.
The purpose of watertight bulkheads is to prevent a sinking if one compartment is flooded. Having a seperate pump for each compartment accomplishes this, (the redundancy is the number of compartments, it is not neccessary to have redundant pumps in each compartment as would be if the boat had NO bulkheads.
I.E. My 36 ft boat has one bilge running the entire length of the boat, I have two bilge pumps one forward, one aft that are on seperate batteries, one on ehouse, one on engine starting, one has a higher float than the other and comes on only if the first one is overwhelmed.
Since you have multiple bulkheads 1 pump each, is twice the redunduncy of my boat already.
If you really want the one pump rules all method, there is in fact a solution. Parker makes a sealed solenoid valve that operates from 12vdc, (or 24vdc), it comes in a variety of sizes from 1/4" to 4", their 3/4" or 1" valves should be in the ballpark of what you need. Simply plumb one valve in line to each pickup, and wire to a float switch in that compartment. When the float activates it will open the correct solenoid, as well as signal the very large master pump to turn on. Problem solved.
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #18 of 18 Old 05-23-2012
Normally a bilge pump manifold is all closed. If there is a problem ,open the appropriate valve and turn on the pump.The automatic electric bilge units in each compartment should take care of small stuff if that's too complicated.
Tags
bilge , bilge pump , bulkhead , design , hosing
cw manual bilge pump, bike pump type b40Ibis Gear & Maintenance 2 04-27-2011 07:26 PM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Brand new bilge pump that doesn't pump.... ugh Lancer28 Gear & Maintenance 6 02-08-2008 08:26 PM
bilge pump DQ halyardz Gear & Maintenance 3 06-04-2002 07:36 PM
