01-05-2004
Lifelines
I rigged my last boat with rope lifelines when the wire ones needed replacing. You can buy rope that easily exceeds the breaking strength of wire, you can do it yourself, and it is usually cheaper. I just used a standard open body turnbuckle to tension one end. I had no gates, so it made the job easier. If I needed to replace my present lifelines (which I don''t) I would do it with rope again.
