Engine Mounts - SailNet Community
post #1 of 4 Old 05-16-2012 Thread Starter
davidpm's Avatar
Engine Mounts
Here is a video of the engine in neutral and idle.
As you can see the first mount port aft is vibrating between the mount and the stringer.
The second mount starboard aft the washer under the top nut is vibrating.
I don't know how long this has been. How would you view this situation.
Fix immediately tow to repair.
Drive to repair about 1 hour or less
Worry about it in the fall.
davidpm is offline
post #2 of 4 Old 05-17-2012
Tartan 27' owner
CalebD's Avatar
Re: Engine Mounts
David,
I know that is not your boat. I also know that diesels knock about a lot and need a firm footing, as does any engine.
Rocking like that of the engine on it's bed is not good for the shaft when it is spinning. Either the stuffing box or bearing will begin to wear excessively or both.
The engine needs to be aligned and tightened down with bolts that won't come loose. It may also require using some shims to get the alignment straight and true.
There are threads about doing an engine alignment but in a nutshell it is about getting the dog to line up with it's tail - that is, getting the shaft straight through the bearing and lining up the engine so it meets the shaft squarely in all planes.
Shims, if you need them are usually made of metal (SS) and slide around the mounting bolts under the engine. McMaster-Carr sells them and they are cheap if you know what you need.
Everybody has one:
CalebD is offline
post #3 of 4 Old 05-17-2012
celenoglu's Avatar
Re: Engine Mounts
Drive to repair about 1 hour or less.
celenoglu is offline
post #4 of 4 Old 05-17-2012 Thread Starter
davidpm's Avatar
Re: Engine Mounts
Thanks I'll recommend to the boss to get it done.
davidpm is offline
Engine mounts GaiaOrion Gear & Maintenance 6 06-05-2011 12:38 AM
PSC 34 Engine Mounts cvsheppard Pacific Seacraft 11 04-12-2010 08:41 PM
PYI Engine Mounts and PSS cvsheppard Gear & Maintenance 2 08-08-2009 10:11 PM
Need Engine mounts.. RDV Gear & Maintenance 2 09-05-2006 02:15 PM
