05-16-2012
Morgan 33 O.I. Perryville
Re: Milky white hot water
A couple of thoughts come to mind. First, if you allow the water to cool in the glass does it clear? If not then it's not lime scale or tiny bubbles that can sometime form when water is overheated.
Their could be a contaminant in the tank that does not show when the water is cool or cold, but appears when the water is heated. Run some cold water into a cook-pot, heat it up on the stove and see if it changes opacity. If it does change opacity prior to boiling, bring it to a rolling boil and see if it clears at that point. If it clears while boiling it is likely a bacterial contamination. If it doesn't clear when brought to boiling, then the contaminant may be in the form of oil leaking into the system from the engine.
This is a difficult problem to diagnose without seeing it first hand. As a last resort, you can take a sample of the water to the local health department and have them analyze it for you. More often than not there is no charge for this service and it only takes a few days to get the test results.
Hope this helps,
Gary
