A 55Ah AGM battery is enough to start a 40hp engine? - SailNet Community
post #1 of 2 Old 05-17-2012 Thread Starter
The AGM battery is this one:
AGM 12/55 | Mastervolt Marine
Model AGM-55Ah
Nominal voltage 12V
Nominal capacity (C20) 55Ah
Reserve capacity* 80 min
Number of cells per battery 6
Maximum charge current: 15.3A
Approximate weight: 17.0 kg
BCI group number 63
CCA to DIN 300A
CCA to SAE 480A
MAXIMUM DISCHARGE CURRENT
Continual discharge: 50A
Discharge time t ≤ 2min: 150A
Discharge time t ≤ 10sec: 300A
http://images.mastervolt.nl/files/ManualAGM111219.pdf
The engine this one:
Sail Drive - LDW 1404 SD - Lombardini Marine - Motori entrobordo diesel marini e gruppi elettrogeni per la nautica - Inboard diesel marine engines and generators
post #2 of 2 Old 05-17-2012
celenoglu's Avatar
Re: A 55Ah AGM battery is enough to start a 40hp engine?
Yes, this is good enough.
celenoglu is offline
Yanmar 3YM 30 start battery Brahmany C320 3 03-06-2011 06:00 AM
Engine Start Key bacampbe General Discussion (sailing related) 11 04-05-2010 09:29 PM
Battery Design: Start + 4 6V T-105s SausalitoDoug Gear & Maintenance 15 04-23-2009 10:55 PM
Start Battery Cruisingdad Gear & Maintenance 35 12-25-2006 02:01 AM
