interior paint question - SailNet Community
post #1 of 9 Old 05-17-2012 Thread Starter
Cal28's Avatar
I am down to mostly fiberglass on the interior hull ... any suggestions for further prep before I paint ... perhaps a base coat of some kind to fill in the ridges and smooth ... planning on using good quality latex ...
Thanks in advance
"It is only with the heart that one can see rightly; what is essential is invisible to the eye."
Antoine de Saint-Exupery
Cal28 is offline
post #2 of 9 Old 05-17-2012 Thread Starter
Cal28's Avatar
Note that I couldn't upload photo to this thread from my phone ... but I did manage to upload it to my gallery ... under CAL 28
thanks
Cal28 is offline
post #3 of 9 Old 05-18-2012
tommays's Avatar
Re: interior paint question
save your money and use valspar exterior works great and tastes like chicken
Pretty sticks to anything that has has been sanded and wiped down and seems fine without any primer anfter 16 months
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #4 of 9 Old 05-18-2012
JimsCAL's Avatar
Don't use an interior latex paint. It will get dirty and covered in mildew in short order. A high build primer might smooth out the surface before you apply the topcoat.
JimsCAL is offline
post #5 of 9 Old 05-18-2012
Barquito
Barquito's Avatar
Just curious what the difference is? I was thinking of using a porch/basement paint.
Valiant 32
Barquito is offline
post #6 of 9 Old 05-18-2012
My recommendation is a an oil based paint with "low odor". Works well, and any smell that might be there goes away quick with a high durability and "stickiness" to adhere to anything you put it on (other than on latex paint of course). I wouldn't bother with a primer and save your money, instead fill in the cracks and holes with a proper filler and sand nicely, that should be fine.
My blog on boat related stuff:
GraemeInCanada is offline
post #7 of 9 Old 05-18-2012
I don't discuss my member
zz4gta's Avatar
I used brightsides with nothing more than a wipe down. Didn't do well with standing water, so sanded and then primed with Kills exterior, and painted. Much better 'bite'. The inside of my boat get soaked during races, so an oil based exterior paint will probably work just fine. I was painting over gel coat.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #8 of 9 Old 05-18-2012
Senior Slacker
SlowButSteady's Avatar
A high quality gloss or semigloss enamel will work, while flat or eggshell paints will mildew more easily. Some exterior paints used to have nasty additives in them to keep the mold/mildew at bay, and you don't want to use them inside (even when dry they release small amounts of toxins into the air). I don't think that this is the case anymore. But, you might want to read the label carefully. Bath/kitchen-grade enamels work well. There are some oil-based enamels on the market that clean up like latex paints. These use some sort of emulsion/micro-encapsulation mojo that doesn't release the oil until the paint starts to dry. Very cool stuff. It goes on more or less like latex, but looks like oil-based enamel when dry.
Whatever you use, make sure you scrub the surface with TSP. Scrub the Bejezzus out of it, rinse it, and scrub it again. Wipe it down with acetone or MEK right before you paint. Fiberglass resins have a wax mixed in with them that rises to the surface as it cures (sometimes it's sprayed on afterwards, but the effect is the same). This wax seals the surface from the air and allows the resin to fully cure (otherwise it will always be a bit tacky). If you don't get ALL of this wax off, the paint will eventually peel. A PO of my boat painted some surfaces without taking the wax off, and now I'm having to deal with it -- not fun.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #9 of 9 Old 05-18-2012
Old as Dirt!
svHyLyte's Avatar
Thanks in advance
You might find it worth picking up a copy of Don Casey's book, "This Old Boat". It contains a wealth of information including the merits of various paints.
FWIW...
svHyLyte is offline
Interior Paint Suggestions diamondmyk Gear & Maintenance 28 07-18-2013 07:26 PM
INTERIOR paint question Kiltmadoc Gear & Maintenance 27 04-13-2011 07:32 AM
paint texture interior rrgane Gear & Maintenance 0 05-24-2009 10:49 AM
Interior Paint ian6460 Gear & Maintenance 4 11-26-2004 07:23 AM
Best interior paint? sneuman Gear & Maintenance 1 03-31-2003 02:09 AM
