Raw Water Strainer - SailNet Community
post #1 of 3 Old 05-18-2012 Thread Starter
Boat shopping
Raw Water Strainer
Hello all,
I'm installing a freshwater cooling system on my atomic 4. Currently, there is a 3/4", all plastic, raw water strainer in place. I was thinking of adding another on the outlet side on the raw ater pump. The disintegrating impeer seems to be pretty common and the 2nd strainer can catch the peices if that ever happens.
My questions are;
1) are the plastic strainers any good?
2) any recommendations on strainers?
3) i'm thinkind of replacing the plastic one and adding the new one, is that a complete waste of money to replace the one thats there?
Thanks!
Danny
Viking 33
Buzzards Bay
SloopDogg is offline
post #2 of 3 Old 05-18-2012
Senior Cruiser
sea_hunter's Avatar
Probably not a good idea installing a strainer after the RW pump. Bits that break off will be found in the tube stack or will be exhausted overrboard. Added restrictions will merely overwhelm your cooling system. Replace the old one withe a larger new and improved.
sea_hunter is offline
post #3 of 3 Old 05-18-2012
Re: Raw Water Strainer
After looking at what some local sailors had on their boats, and researching it here and elsewhere, I went with this Perko strainer: STRAINER INTAKE 1/2" IPS BRONZE 127070. (And that's where I bought it and all the associated hose, clamps and other bits.)
Jim
SEMIJim is offline
Sea Water Strainer joub Gear & Maintenance 14 10-22-2015 05:35 PM
Sea water strainer Install mogul11 Gear & Maintenance 8 05-12-2009 10:39 AM
Raw-water strainer maboyer Gear & Maintenance 6 12-05-2007 02:34 PM
Raw water strainer size?? Northeaster Gear & Maintenance 3 07-17-2007 10:41 PM
Raw Water Strainer Jotun Gear & Maintenance 27 03-30-2007 11:33 PM
