Glue, screw or rivet spinnaker pole ends? - SailNet Community
 1Likes
  • 1 Post By svHyLyte
post #1 of 9 Old 05-18-2012 Thread Starter
rhr1956's Avatar
I'm ready to attach the end fittings to the aluminum pole. There is a label on the fittings that say "Use machine screws only for attachment to pole". On the website (forespar) they have pole kits which include epoxy for attachment of end fittings. Not really sure why it makes much difference. Originally I planned to epoxy the fittings to the pole and follow up with three aluminun pop rivets. What do you think?
rhr1956 is offline
post #2 of 9 Old 05-18-2012
Old as Dirt!
svHyLyte's Avatar
Re: Glue, screw or rivet spinnaker pole ends?
Considering that you might need to replace the tube at some point if its damaged, or a damaged end fitting without harming the tube itself, it would be wise to use machine screws with a little TefGel applied to the threads. Someday you, or a subsequent owner, will be glad you did.
FWIW...
rugosa likes this.
svHyLyte is offline
post #3 of 9 Old 05-18-2012
DrB
Mehanical Fasteners for Alumnim spars, Epoxy for Composite.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #4 of 9 Old 05-18-2012
As HyLyte said. Because spinnaker poles are often broken, and being able to re-use the ends really cuts replacement costs. You could epoxy the ends and then use heat to break them free--but that would probably detemper the metal and ruin them, bad idea.
So, machine screws or pop rivets. A lot of commercial poles have used pop rivets. If you use machine screws, no big deal, a machine shop should be able to tap and drill the six? holes you need for a couple of bucks per hole, maybe $20-30 for the whole job. In which case I'd use LocTite on those screws.
hellosailor is offline
post #5 of 9 Old 05-19-2012 Thread Starter
rhr1956's Avatar
Just curious...how do spinnaker poles typically get broken? I can see them getting dented, but broken??
rhr1956 is offline
post #6 of 9 Old 05-19-2012
rugosa's Avatar
When the poop hits the fan.
Potential to remove for casting failure, dented/bent tube, replacement of internal lines if whisker pole. BTW non-marine rivets they will rust, drill 'n tap makes for easy service
rugosa is offline
post #7 of 9 Old 05-19-2012
overbored's Avatar
depends on the end casting size if it is thick then you will have to use screws as the rivets may not be long enough to go all the way through and hold good. on the smaller poles rivets are ok. pop rivets are hollow and not as strong as screws. If you did have to replace any part the rivets are easier to drill out then remove old screws that are corroded in the aluminum. if you seal the end to keep water out some of the poles will float if lost overboard. I have one that is riveted with ss pop rivets and sealed with silicone. my carbon one is epoxied in place. if you do use screws you should use flat head type as the round heads take out big chips of gelcoat or paint when they hit the deck or rail
"GOLD RUSH" PRINDLE 16
overbored is offline
post #8 of 9 Old 05-19-2012
Catboat
Please use 1/4-20 machine screws. Two years ago I had pop rivets on the 24' boom on a 23' boat(gaff rig) fail spectacularly. The aft end of the boom shot skyward then passed between the port stays and the mast on its way to becoming a new bowsprit. We're lucky no one was killed! a Spinnaker pole isn't much different.
Spyder is offline
post #9 of 9 Old 05-19-2012
Lightbulb Positive Floatation note
Good idea to plan for the day when things get a little sporty during the takedown and the pole goes over the side. Seen it happen. what with rivet holes and etc they sink faster than you might imagine. This will only happen when you are in winds over 15 and seas over 2', and control over the outcome of sail change and course change is uncertain for a little while.
Excited utterances may be involved, also.
I have filled the pole on our present boat and on the boat prior to this one with foam "peanuts" before attaching the ends. Of course neither of those poles has yet to go OB....
LB
olson34 is offline
whisker pole ends montenido Gear & Maintenance 12 01-08-2012 07:26 AM
Using spinnaker pole to pole out jib when sailing downwind... sweetdreamyamaha Seamanship & Navigation 5 09-08-2010 10:39 AM
spinnaker pole set up 83XT4 Pacific Seacraft 3 12-21-2009 04:48 PM
Using a spinnaker pole instead of a whisker pole aphil138 Gear & Maintenance 14 03-31-2008 02:51 PM
Wanted a Whisker Pole and a Spinnaker Pole matthiesen Gear & Maintenance 0 02-22-2008 02:10 PM
