Shower sump pump failure - Page 2 - SailNet Community
post #11 of 12 Old 06-24-2013
Re: Shower sump pump failure
We own a 2008 B43 with two of these type sumps.
If you have not already done so (which I think you have) you need to replace the sump switch box that you are talking about. It has a timer relay and it sounds like yours has failed. It's Beneteau p/n 064347. I would also suggest you not trash the old switch box since it does work in the override position. If, in the future, the new box completely fails you can install your old switch box until you secure a new one or change systems completely for a new sump system.
JT
jtaylo9576 is offline
post #12 of 12 Old 06-24-2013 Thread Starter
Thanks for the reply. Yes we solved this problem, but it is good for other Beneteau owners to know and as such I am replying.
You were right. We had to replace the sump switch box However, the replacement also had the manual switch so there was no reason to keep the old one. I guess we could have.
The float switch was fine. We got the part from Beneteau's Parts department.
nika44 is offline
Shower Sump Pump Bump Gear & Maintenance 10 10-16-2011 05:57 PM
How-To for Shower Sump tomperanteau Columbia & Coronado 0 05-17-2011 03:42 PM
Endeavour 40 shower sump eskimo1941 Announcements and Suggestions Box 3 09-18-2009 08:06 PM
Air Cond to shower sump? Necessary or not Pamlicotraveler Gear & Maintenance 8 07-28-2008 04:12 PM
Installing a shower sump? AndrewB Gear & Maintenance 4 10-09-2001 07:31 AM
