Yamaha 8 HP Outboard - SailNet Community
 1Likes
  • 1 Post By dabnis
post #1 of 5 Old 05-20-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
After not being used for probably 2 years we tried to start our dink outboard. Changed plugs and cleaned fuel strainer first, of course. No luck. Engine won't start. Also if I try to crank it while in gear the pull cord will not turn the engine. I also found 2 wires inside disconnected that I could not find where they might connect to. Any ideas?
brokesailor is offline
post #2 of 5 Old 05-20-2012
Courtney the Dancer
jrd22's Avatar
Re: Yamaha 8 HP Outboard
2 or 4 stroke?
If 2 stroke (4 stroke could be a lot of things) it's probably the carb. Take it off and disassemble (not difficult), soak in carb cleaner and blow it clean with compressed air.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #3 of 5 Old 05-20-2012 Thread Starter
SV Skalliwag #141
2 stroke.
post #4 of 5 Old 05-20-2012
"Two wires disconnected"? You might try to see if it is at least getting spark. Take the plug out, put the cap back on it, ground the base of the plug to the engine block or use a jumper wire, and then crank it over. You should see a nice blue spark between the electrodes. If you do it is likely starving for fuel. Spray some gas into the carb intake and see if it fires. As mentioned earlier it is likely the carb has some debris in it.
Paul T
sawingknots likes this.
dabnis is offline
post #5 of 5 Old 05-20-2012
i would add that gas thats allowed to stand/evaporate in the carb tends to turn into a kind of shilac[sic]and clog the ports,but dabnis is right,checking for fire at the plugs is the easiest and fastest check,if thats not the problem then fuel is he next likely culprit
sawingknots is offline
yamaha 9.9 outboard help. meboater Gear & Maintenance 12 08-22-2014 06:00 PM
Yamaha outboard question meboater Gear & Maintenance 12 10-17-2011 08:03 PM
carb question for yamaha outboard Incantation Gear & Maintenance 1 11-01-2010 01:43 AM
Yamaha Outboard Parts? Iflyka200s Gear & Maintenance 0 05-09-2008 10:36 PM
Yamaha Outboard? rhbroehl Gear & Maintenance 3 12-13-2001 02:16 PM
