Economical Hand-Held Chartplotter? - Page 7 - SailNet Community
 10Likes
post #61 of 69 Old 05-22-2012
Re: Economical Hand-Held Chartplotter?
Originally Posted by Ritchard View Post
We have no data plan - it's not necessary. Unlike apps like MotionX-GPS, the complete charts are downloaded to the device when you purchase them. It needs no data feed after the fact.
However, you *MUST* purchase the correct iPad with the full-function GPS chip, as my friend found out recently. He was quite taken with the chartplotter function of the iPad on my boat, and went out and boat an iPad 3. The lesser models ( I am not sure which) will not work as a standalone GPS unit. He had to shell out the $100 he saved on the cheaper iPad on a bluetooth GPS puck.
I brought my boat from Cleveland Ohio to Toronto Ontario late last summer. All of the charts for the trip - plus the rest of the Great Lakes and some of the St Lawrence and the Erie Canal system cost me $35. I think the app itself is free? (Yes of course I had paper chart backups). We already owned the iPad, so how's that for economical?
Okay, thanks for the post. That clears up a lot.
Curtis
curtcee is offline
post #62 of 69 Old 05-22-2012
Originally Posted by NewportNewbie View Post
I'll start a new iPad thread. Maybe we should be putting these posts there as its not quite what the OP was looking for and this info which is great for those looking for it may get lost in this thread. I wasn't looking to starting an apple vs the world thread. Lol.
If you do start a new thread, for those of us who are willfully ignorant, I'd like to see why anyone should choose an Ipad for a chartplotter over an Android tablet for a chartplotter. But if it's going to start another war, maybe you should just private message me.
Curtis
curtcee is offline
post #63 of 69 Old 05-22-2012
Nearly an Old Salt
This is incorrect as it suggests there is a less then functional GPS model.
Folks its simple, The 3G iPad has a GPS receiver, the non 3G ( i.e. wifi only ) has no GPS chipset.
The GPS is assisted GPS, that means the first fix time is accelerated buy using cell tower triangulation as well as the emphermis data is accessed if possible over 3G rather the downloaded from the sat. But in the absence of 3G, The GPS chip will work as normal GPS does.
see simples
goboatingnow is offline
post #64 of 69 Old 05-22-2012
Nearly an Old Salt
I have Transas iSailor on the iPad. I got iSailor when I got the boat. I just looked at what was on the iTunes store at the time, compared the cost of the software and the charts against the apparent (fingers crossed) capabilities of the software. I picked okay. I have been really pleased with the software, but it is clearly a work in progress as they are adding features with each release. One feature it lacks, but is promised, is Active Captain integration. This would be a cool overlay feature, but would of course require Data, whether Wifi or Cellular.
I have MotionX on the iPhone, but not the iPad - I don't get it, is there a way to store maps/charts? Once I am out of cell data range, the thing is pretty useless. Edit: Nevermind this last bit. All this talk, I just figured out how to download NOAA charts in MotionX.
MotionX caches charts, you need to load all you need before going out of cell range
post #65 of 69 Old 05-22-2012
MarkCK's Avatar
After skimming through the iwars here I figured I would get on the bandwagon of highjacking this thread. Will these apps work on an iphone 4, and can I download the free noaa charts. And if I do all this will the screen be to small anyway to be worth doing?
always in decline-never hitting bottom
MarkCK is offline
post #66 of 69 Old 05-22-2012
NewportNewbie's Avatar
Curtcee...Android vs iPhone is simply the availability of apps and the quality. Apple does approve all iPad apps, so there is a bit of quality control. Also its guaranteed not to try and mine your device for your personal info and send it to China...that has happened in Android apps.
MarkCK...I use my iPhone 4s as a backup. Its fine and works ok...the screen is the limiting factor. Because I don't have a waterproof case yet for the iPad, I use the iPhone in bad weather. I have a waterproof case for the iPhone. I use the Lifeproof case. You can get them from Bestbuy and its a very solid case.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #67 of 69 Old 05-22-2012
MarkCK's Avatar
People have been debating back and forth on what works best. Can you give me a brief "how to" to make this all work? What to download first and then how to load the charts. Preferably the free ones. And will the charts work on inland lakes also?
MarkCK is offline
post #68 of 69 Old 05-22-2012
No more curry buffets
Ritchard's Avatar
MarkCK, you might start with iSailor on the iphone. It's free, and you can download and play with a few free charts, then if you like it, buy the charts for your area. If you're in the US, each region is cheap. I'm in Canada, and the charts are more expensive here. You download the charts from within the app. It's in the setup menu, and really easy.
Alternately, you can try InavX. It's $49.99 but the NOAA charts are all free from them.
Were it me, I'd go with door number 1, and see if you're okay with the screen size, etc.
Bashing about on Lake Ontario and Beyond
"Ariel" '79 Endeavour 32
Ritchard is offline
post #69 of 69 Old 05-23-2012
I love my iPad for surfing and email while traveling but it is lame as a chart plotter. Bad screen in sunlight and not water proof. Waterproof cases make the touch screen much less responsive. Garmin has the largest variety of handhelds by far, you should be able to find one that fits you needs plus it is easy to transfer your waypoints and routes between units.
LinekinBayCD is offline
Hand held gps Slayer General Discussion (sailing related) 39 02-15-2010 07:03 PM
Use of hand-held VHF when not on board patrickstickler General Discussion (sailing related) 16 06-04-2009 07:38 AM
Best Hand Held Radio Serve General Discussion (sailing related) 26 10-12-2008 11:48 PM
Hand held GPS hoppy Gear & Maintenance 12 08-11-2004 02:57 PM
Hand held RDF Nantascot Cruising & Liveaboard Forum 1 01-05-2002 12:23 PM
